Thread: Audi A4 wheel bearing
  1. Audi A4 wheel bearing
    Jul 2007
    I have a Audi A4 1.9TDI and need to get my wheel bearing off the drive shift to enable me to change my CV boot.
    could anybody advise me how to remove the wheel beering?
    134 Post(s)
    2014 Post(s)
    You need to release the CV centre nut and the two lower arms which can be tricky without the special ball joint extractors.
    Jul 2007
    I've got that far. I've removed the 14mm allen key bolt and pulled the wheel housing out of the way. I cannot get the CV joint off the end of the drive shaft.
    134 Post(s)
    2014 Post(s)
    You either remove the shaft from the car, clamp the shaft in a vice and hit the joint very hard with a copper hammer or buy VW tool 3207.
    Jul 2007
    somerset
    8 Post(s)
    Hi, you can use the bolt from the driveshaft, thread it in to the cv joint till it bottoms out and turn it a few more turns with a socket, this should jack the joint apart, this worked ok on my 1996 1.8 turbo. good luck, by the way, you only need to remove the rear arm and put the steering on full lock, the driveshaft will pull out ok. How did you remove the front tapered lower joint as i have had huge problems with this, any one got any ideas?
    134 Post(s)
    2014 Post(s)
    A special tool from KLANN. Not all of them will come out by removing the one arm; it seems to vary according to year and model.
  1. Passat Front bearing
    By ashab in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-08-2007, 11:45 PM
  2. Replies: 3
    Last Post: 07-07-2007, 04:25 PM
  3. The rear wheel bearing wanted
    By Laurence Tsai in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-02-2007, 03:25 PM
  4. Replacing rear bearing
    By Jon_Halibut in forum Audi A3 - Archive Topics
    Last Post: 21-12-2006, 11:37 AM
  5. Audi S4 Avant wheel faults
    By submissionpete in forum Audi A4 - Archive Topics
    Last Post: 21-09-2006, 08:19 AM
