Thread: Pole Rear Break Hub Removal ??
  1. Pole Rear Break Hub Removal ??
    Feb 2007
    Cheshire
    I tried to get my offside brake hub off over the weekend to inspect the brake shoes, It was almost impossible. I managed to free the rusty hub but could not get it off over the brake shoes without damaging them in some way. I could not see a way of making the overall diameter of the brake shoe position so as to make getting the hub off easily. Does anyone know if there is an easy way to get the hub off. Is there an adjuster/release nut for the auto adjusting brakes (if they have this) on the back of the backplate ?
    Any simple advice would be appreciated.
    135 Post(s)
    2038 Post(s)
    What type of Polo???
    Feb 2007
    Cheshire
    2001 1.4 Polo "Match"
  4. Wink
    135 Post(s)
    2038 Post(s)
    Taking the drivers side as an example, look through on of the wheel bolt holes when positioned at around the 2 o'clock. You will see a hole which has the tail of a spring in it and this hole is at the base of a wedge. Using a long pointed stick (we use an old screwdriver ground to a point) lever the wedge upwards and you will hear/feel it rasp back to the stop. It is also a good idea to make back the handbrake cables right off. When you put it back together, have an assistant press the brake pedal down as you lever the wedge fully down. This will jam up the drum and a sharp thwack with a copper hammer should free it off but if not, gently tweak the wedge back a step in the rasp. When the drum runs freely with a little bind, set the handbrake cables up for three clicks.
    135 Post(s)
    2038 Post(s)
    Why is there a Wink at the top of my post???
    Feb 2007
    Cheshire
    Many thanks for your help on this. All I need now is a break in the weather one evening so I can have a look and try it out.
  7. Re: Pole Rear Break Hub Removal ??
    Jul 2007
    Herne Bay
    or you could remove the outer wheel bearing and use the wheel to wind the hub off (assuming you have left the wheel on?
  1. Rear Seat removal A6 Avant
    By reesy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-04-2008, 11:35 AM
  2. rear bumper removal
    By bigb1970 in forum Passat - Archive Topics
    Last Post: 08-11-2007, 10:23 AM
  3. 2002 Audi A4 saloon - rear break light replacement
    By MF121 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-07-2007, 07:12 PM
  4. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
