Thread: 2.0TFSI SE Lack of power
  1. 2.0TFSI SE Lack of power
    warp_speed Guest
    Can someone please give advice regarding my 2007 2.0T Audi A4. It seems to be lacking power and runs out of puff when I hit 100mph, foot almost to the floor but it seems to lack the quickness I expected from a 215 HP engine. I've only had the car for a few months, but its no where near as quick feeling as the 3.0V6 (petrol) B6 I had.
    Done a check with my full version of VCDS and there is no fault codes listed, coolant sensor seems fine, what other values should I be looking out for or is there any easy things I can check? I heard the PCV valve is a problem but would that be a problem on a 4 year old 32k mile car?
    Thanks in advance
    Output from VCDS while idling, I noticed that the actual boost doesn't change when I hit the accelerator, unsure if thats significant.
    VCDS Version: Release 10.6.4 (x64)
    Data version: 20110418
    08:35:20
    95.0°C Coolant Temperature
    14.3 % Engine Load
    0.77 ms Injection Timing
    2.36 g/s Intake Air Mass
    720 /min Engine Speed
    39.0°C Intake Air Temperature
    0.0 % Wastegate (N75) Duty Cycle
    290.0 mbar Boost Pressure (specified)
    1000.0 mbar Boost Pressure (actual)
  2. Re: 2.0TFSI SE Lack of power
    May 2009
    Glasgow
    The Diaphram in the Recirculation valve on the turbo was perforated on my car and i lost nearly all boost. Changed it and it was like a diffrent car. A bit tight but easy to change.
  3. Re: 2.0TFSI SE Lack of power
    warp_speed Guest
    would the recirculation valve not throw a fault code or ecu light. I get nothing...
  4. Re: 2.0TFSI SE Lack of power
    May 2009
    Glasgow
    I got the car scanned and it didnt show any faults. At the time of mine going, the latest revision of this valve was "D" should be about 50 quid from the dealers. While you are there, get your Coil Packs checked to see if they need changing. There is a Product enhancement campain to change these to the latest revision free of charge
  5. Re: 2.0TFSI SE Lack of power
    warp_speed Guest
    Quote Originally Posted by Roonster View Post
    Thanks for the info, can I ask how many miles your car has done, I can't believe that at 32k I need to change something and here was me thinking the BUL engine is solid, or is the engine solid but everything attached to it kind of crap.... :-)
  6. Re: 2.0TFSI SE Lack of power
    May 2009
    Glasgow
    My car has only done 42k. Have a read at this.
    http://www.golfmkv.com/forums/showthread.php?t=24952
  1. Please Help A3 2.0TFSI Quattro power problem
    By cgball in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-05-2009, 09:05 PM
  2. a4 lack of power
    By easy in forum Archive posts
    Last Post: 09-01-2008, 01:14 PM
  3. 1.8T Lack of power
    By Bevsy in forum Golf MK4 - 1999 - 2004
    Last Post: 07-12-2007, 02:51 PM
  4. Lack of power
    By twosox in forum Passat - Archive Topics
    Last Post: 28-01-2007, 03:22 PM
  5. A4 1.8T lack of power
    By Big D in forum Archive posts
    Last Post: 19-02-2006, 09:47 PM
