Thread: 2.0 TFSI Valve carbon deposits
  1. 2.0 TFSI Valve carbon deposits
    Hi all,
    Thought I'd post up some pictures of what my valves and inlet tract looked like when I recently opened it up. The car has done 50k miles and been run on 98RON minimum since 35k miles (when I bought it). Car is also a 2004, early B7 registration. It has also been on the shortlife service schedule since bought by me using dealer approved (not sure of the grade) oil.
    I'm only showing one of the inlets as they were all pretty much in the same condition.
    As you can see, the valves are quite heavily coated and the "splitter plate" which sits before them was also heavily coated.
    I cleaned them all up with toothbrushes and carburetter cleaner, including the injectors.
    Torque, rather than power has improved since.
    Get educated or get ripped off!
  2. Re: 2.0 TFSI Valve carbon deposits
    warp_speed Guest
    I seen this on US 2.0 FSI engines, it was something about the oil quality and the fact that the FSI means the petrol vapour doesn't come in contact with the valve inlets and hence doesn't clean the oil deposits off the valves. It can be a big problem especially when valves don't close properly. Unsure if the old 15ml of redex down each of the inlet ports and leave for 30 mins would help/work or resolve this issue?
  3. Re: 2.0 TFSI Valve carbon deposits
    Nov 2009
    swindon uk
    How was the wear on the valve guides?
    Audi A4 saloon, 2.0L tdi s-line. Retrofitted cruise control, DIS and MFSW. VCDS user.
  4. Re: 2.0 TFSI Valve carbon deposits
    It's the problems many us cars were having which led me to open it up. i'd say that the only chance of getting this stuff is through scrubbing. redex alone won't touch it. valve guide wear seems non existent and oil consumption is what i would describe as normal.
  1. Carbon canister solenoid valve
    By djm1278 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-10-2010, 10:25 PM
  2. Creamy Deposits on the Dipstick?!!
    By fingers in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-02-2009, 09:10 PM
  3. 1.8T Carbon Deposits
    By perfection in forum Audi A3 - Archive Topics
    Last Post: 09-04-2008, 11:03 AM
  4. 1.9tdi mk3 inlet valves heavy carbon deposits
    By Royzboy in forum Golf MK3 - 1993 - 1999
    Last Post: 28-10-2007, 08:46 PM
