Thread: will b5 and b6 wheels fit my b7
  1. will b5 and b6 wheels fit my b7
    Feb 2009
    I have a 2007 A4 B7 on 18"s and im looking to buy a set of winter wheels for it,
    would a set of 16"s or 17"s off A B5 or a B6 fit ok??
  2. Re: will b5 and b6 wheels fit my b7
    Norwich
    B6 wheels definitely will as I run a set for my winter wheels- I know diddly squat about the B5 era A4 though so can't help there I'm afraid
  3. Re: will b5 and b6 wheels fit my b7
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Hi buddy, the B5, B6, and B7 all run a pcd of 5x112 and a centre bore of 57 or 57.1mm , so the wheels will interchange.
    The only issues you need to check on will be the ET figure which determines how much the wheel sticks out of the wheel arch or tucks into the arch, the other issue to take into account is whether the 16" rim actually clears the brakes and suspension etc.
    So the big answer is yes and the detail is in finding the suitable rim, they are out there so do an archive search for more info to suit your model
    Stuart
  4. Re: will b5 and b6 wheels fit my b7
    Oct 2009
    10 Post(s)
    As a second point I would enlighten you that the B6 and B7 A4 are essentially the same car with a few cosmetic enhancements, so straight swaps.
    Good luck
    Stuart
  5. Re: will b5 and b6 wheels fit my b7
    Feb 2009
    Cheers for that, ill have a look around!
    Regards Bryden
  1. Question Will these wheels fit??
    By h3rman in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-10-2009, 06:57 PM
  2. Wheels To Fit A4 B5!!!!
    By adsisbest in forum Wheels and Tyres
    Last Post: 03-02-2009, 12:06 AM
  3. Any Wheels To Fit A4 B5
    Last Post: 03-02-2009, 12:05 AM
  4. Will these wheels fit?
    By sam4191 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-01-2009, 05:35 PM
  5. Will these wheels fit
    By Nezmond in forum Audi A3 - Archive Topics
    Last Post: 08-01-2009, 02:46 PM
