Thread: Engine Noise on cold start
Results 11 to 20 of 28
  1. Re: Engine Noise on cold start
    Sep 2009
    Yup - major problem! The garage have had the car for over a week (and still have it).
    The Cam adjuster is causing this!! VW have a bulletin on this as it is a common fault apparently, and costs many £000's to fix. Over 8 hours of labour stripping the engine down plus parts and is covered under warranty!
    Guys - listen carefully to your golf when it starts!! Not all owners pick it up, but it can be nasty if left too long. Like I say, when the engine fires, it sounds like a card board tube against bicycle wheel' spokes for about 2-3 seconds. It's not a diesel engine type sound, but different. Very much a growl (GRRRRRRRR) sound. If you do a search on the Audi part of this forum, it has afflicted the A4....
    Hope this helps.
    Golf 1.4 TSI SE, 5DR Manual (Metallic paint), '09/59
  2. Re: Engine Noise on cold start
    Sep 2009
    Still in the Shop
    They put it together and then found that one of the valves needs replacing! New parts ordered and engine stripped again!
    Not what I expected from a £18k car!!
  3. Re: Engine Noise on cold start
    South London. UK
    The day my car exhibits that sort of problem, I'll tell them to repair it and keep it for a book value sale and then move on!
    2016 VW Golf MK7 Match Edition 1.4TSI 125ps 5dr in Reflex Silver.
  4. Re: Engine Noise on cold start
    Otley West Yorks
    Looks like I could have picked the Wrong Engine ! Glad its 3 year warranty but was to be a long term Car
    One of the reason I went for VW was there Reliabilty !!!!
    Ex Golf Match Now New Leon 1.4 SE SC
  5. Re: Engine Noise on cold start
    South London. UK
    Never consider VWs for reliability, just badge snobbery!
    Sent from my HTC Desire 'S'
  6. Re: Engine Noise on cold start
    Mar 2010
    London
    I honestly think you've been unlucky Jumbo Golfer but I would be annoyed if a workshop replaced my cylinder head without testing it....what a bunch of Pratt's !
    Your description left us in no doubt about your engines health but IMO the noise described by others is par for the course for a cold start up of 1.4 122 models.
    The loud exhaust rumble is down to the fast idle and advancement of the ignition....which aids warm up.
    TSI 1.4 SE DSG
  7. Re: Engine Noise on cold start
    #17
    Otley West Yorks
    Quote Originally Posted by HHGTTG View Post
    I thought I left that Behind when changed from Audi
  8. Re: Engine Noise on cold start
    #18
    Sep 2009
    Promised back for tomorrow and I've asked for a list of everything that was replaced. Will post back!
  9. Re: Engine Noise on cold start
    #19
    Jan 2009
    I have been a bit puzzled about this valve cam adjuster thing ! Since the advent of modern OHV engines I was not aware of any adjuster as the systems . However reading the forums it appears that buried in the cars hydraulic system (nobody seems to now quite where ) there is an adjuster which controls the vave opening . When this goes wrong you not only get the noise on start up but it very quickly bu@@ers the valves.
    Perhaps the mods should put up a sticky on this forum "BEWARE THE DREADED GRRRRRRR OF DEATH"
    2011 . Golf Match. 1.4TSI Manual 122Ps Steel Grey.
  10. Re: Engine Noise on cold start
    #20
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Alot of modern engine use hydraulic lifters that don't need any valve adjustment.
    hydraulic tappets / hydraulic valves (or hydraulic lifters)
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  1. Engine fan comes on at cold start, heaters blowing cold air when idle
    By walsie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-12-2010, 07:26 PM
  2. Cold Start Clutch Noise
    By aceofharts414 in forum Golf MK5 - 2004 - 2009
    Last Post: 13-08-2010, 12:44 PM
  3. s4 cold start noise!
    By eugenbd in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-10-2009, 08:36 PM
  4. Please Help Noise coming from engine on cold start
    By veej123 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-03-2009, 10:34 AM
  5. a3 cold start engine noise
    By heybails in forum Audi A3 - Archive Topics
    Last Post: 14-02-2008, 06:39 PM
