Thread: rear seat belts
  1. rear seat belts
    Jul 2007
    hi
    i am seeking advice on how to unjam passenger side rear belt webbing on 2001 passat.the problem I have is that a childseat is stuck in situ. It isnt mine Dont ask Just trying to weigh up the pros and cons of replacing car seat £150.0, cutting belt and the replacement any ideas
    thanks
    paul
  2. Re: rear seat belts
    Oct 2006
    Sunny slightly hilly Norfolk
    Right this might sound really stupid, but you need to get the tension off the belt to allow the locking mechanism to unlock. Easiest way is to undo the buckle but that may be difficult. I've found that putting my weight on the car seat forces it into the cushion allowing the belt a little slack which helps. You might be able to get the buckle out then. Not sure if the belt locks if the seat isn't fully located back (like Mondeos) but might be wise to check that too. If they don't work then you may have to cut the belt.
    2016 VW Tiguan Match Edition (Nimbus Grey) , 09 Ibiza 1.4 SE SC (Nayara Blue), 2014 Leon 1.2 SE (Candy White).
  1. Polo Airbag, power steering and seat belts
    By 230k in forum Polo - Derby - Lupo - Fox
    Last Post: 07-04-2008, 11:24 PM
  2. Rear seat cup holders
    By JpH in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-02-2008, 10:36 PM
  3. Rear Seat-Belt issue.
    By Westford in forum Archive posts
    Last Post: 04-04-2007, 02:27 PM
  4. Passat rear seat backs.
    By Bilboy in forum Passat - Archive Topics
    Last Post: 24-06-2006, 03:48 PM
  5. seat belts retracting
    By glynnd in forum Passat - Archive Topics
    Last Post: 24-02-2006, 11:29 AM
