Thread: 2012 CC Sport - looking for help
  1. 2012 CC Sport - looking for help
    Jul 2011
    LA - Lower Akron
    Hi all! Newbie here from another site hoping to gain more in site to the mods and coding I am trying to do on my 2012 CC Sport.
    I am currently looking to retro fit front fog-lights and rear fog lights. Trouble is 2012 has an all new CECM and to boot, the factory schematic of the electronics is not matching up with the cars CECM wiring.
    I have been able to set some codes but basically I am stuck as to why this is not working.
    So before I elaborate, I wanted to see if anyone out there can shed some light on this. I know the pin/slot numbers to an extent and I know some of the coding as well but something is missing too, just can;t figure that out.
  2. Re: 2012 CC Sport - looking for help
    Sep 2009
    Apollo
    We spoke in the VW Vortex but this is a better area for the rear fog light. For reference the other thread and wiring notes are here:
    http://forums.vwvortex.com/showthrea...agCom-for-2012
    You may want to post the original (factory) coding of the 09 module and the final (current) coding here for easy reference in this thread.
    I couldn't help but notice this scan and Byte 18:
    https://www.vwaudiforum.co.uk/forum/s...ssat-CC-MY2011
    I suggested Byte 18 from 7C to 7D but that other vehicle has 76 and I'd assume that was stock since the inquiry was inside / foot-well lighting. You may ask and see if that CC has a factory rear fog and if so, see what happens with that coding.
    -Dana
  3. Re: 2012 CC Sport - looking for help
    Jul 2011
    LA - Lower Akron
    Hey Dana, yeah another Vortex member suggested over here may be a better source.
    It is looking more like a Byte 18 configuration and yes, I did try the 7C to 7D with no results. I got a hold of a 2012 R-Line scan 09 module and it is similar except for the secondary coding.
    Here is what I posted on the Vortex board to you:
    2012 R-Line CC with factory installed fogs:
    Address 09: Cent. Elect. (J519) Labels: None
    Part No SW: 3AA 937 087 B HW: 3AA 937 087 B
    Component: BCM PQ47 H+ 413 0452
    Revision: BC413001
    Coding: 0000000000000000009802219400840440517C8840600D605C 8060200040
    Shop #: WSC 05311 000 00000
    VCID: 3957FE3F09DF
    Part No SW: 3C8 955 119 D HW: 3C8 955 119 D
    Component: Wischer 09101 10 0603
    Coding: 00B795
    Part No: 1K0 955 559 AH
    Component: RLS 281010 05 54 0403
    Coding: 0330ED
    No fault code found.
    ...and here is mine 2012 CC Sport without factory fogs:
    Address 09: Cent. Elect. (J519) Labels: 3AA-937-087.clb
    Part No SW: 3AA 937 087 A HW: 3AA 937 087 A
    Component: BCM PQ47 H 413 0452
    Revision: BB413001
    Coding: 0000000000000000009802059400000040507C8840600D605C 8060200040
    Shop #: WSC 05311 123 12345
    VCID: 3851FCE93776
    Subsystem 1 - Part No SW: 3C8 955 119 D HW: 3C8 955 119 D
    Component: Wischer 20121 10 0603
    Coding: 00B395
    Subsystem 2 - Part No: 1K0 955 559 AH
    Component: RLS 270111 05 54 0403
    Coding: 0330ED
    The coding is pretty much the same except for about 4 Bytes which I was able to understand what options which Bits were checked and unchecked. I think only one did not match up.
    The CECM part numbers are identical except for the last letter of mine having an "A" and the R-Line having a "B". Researched this and found they are identical CECM units, nothing different. I believe the "B" part number replaced mine after production date 5-10-10. My car was built on 10-10-10 and there were changes I believe.
    Byte 18 and HEX is the same for both cars.
    What is different is the second set of coding of the one coding that has the boxes checked but no information regarding what they are for...this is what I spoke of to you before. Could this be the key to how and why the fogs work on the R-line and not the Sport due to coding issues?
    The last part of the coding looks to be the same in 09 section.
    I think we are getting close or are least going in the right direction.
    What is you take on this?
  4. Re: 2012 CC Sport - looking for help
    Jul 2011
    LA - Lower Akron
    Anyone have an full scan of a 2012 R-Line for comparison purposes? I would really like a VIN number more so for reasons of researching CECM model numbers and options in regards to retro fitting my fogs on my 2012 Sport. What I am thinking is that the CECM modules on the R-Lines come installed with different options/programing for the factory installed fogs. I think all 2012 CC's have wiring for those options to an extent but it is mainly the pins/slots on the CECM and programing that determine the output for the models.
  1. New MOT Rules for 2012?
    By Bratty in forum Chat - Anything with wheels
    Last Post: 21-12-2011, 11:38 AM
  2. 2012 A5 Facelift
    By jakerade in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-07-2011, 01:25 PM
  3. Audi A4 2012 facelift ?
    By HighwayTG in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 31-03-2011, 12:11 AM
  4. New 2012 generation A6
    By tlionhart in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-12-2010, 09:06 PM
  5. Attention Euro 2012.........
    By phil miller in forum Chat - Completely Off Topic
    Last Post: 05-09-2010, 08:56 PM
