Thread: audi 80 1992 and vcds
  1. audi 80 1992 and vcds
    Jan 2010
    hengoed
    Anyone fancy a bash at this one.
    My mate owns a 1992 audi 80, anyway to cut a long story short, he lent the car to his son, but when returned he toasted it, obviously something catastrophc occurred.
    He is now rebuilding the engine and has several unknown faults, so can my full version of vcds via his diagnostic plug scan his car and give a readout of known faults, like i can on my audi 2007 a4.
    I know i need a different cable, but don,t want to go to the expense if its not possible.
    thanks john
    2007 A4 saloon 3.0Tdi Tdv QUATTRO.
    Phantom black - Xenons, Bose, Heated Valcona, Cruise, Colour DIS, Satnav, front and rear sensors.
    Hex-USB+CAN VCDS, with a lot to learn.
  2. Re: audi 80 1992 and vcds
    133 Post(s)
    1987 Post(s)
    We did one like that yesterday. There are three plugs under the dash, black, tan and blue. You defiantly use the black plug and if I remember rightly the tan one as I tried the blue one and it did not work. The only problem is that you need the 2x2 adapter but if it is KE Motronic you need a sensitive multimeter, an exhaust gas analyser and a special harness adapter for the metering head to step it up. There is an art to setting these up and the number of people who can do them is falling as we retire, die or don’t work in the workshop anymore. What is the engine code, 3A, ABK?
  3. Re: audi 80 1992 and vcds
    Jan 2010
    hengoed
    Thanks crasher, i,ve been away for a bit, so sorry for the late reply.
    I can,t pretend to understand your well informed answer, but basically are you saying i cannot carry out a scan of the audi 80 without the additional calibration tooling you mention in your reply.
    Basically my mates rebuilt the engine from the ground up, but still thinks theres somthing not quite right, so a scan would/could help point him in the right direction.
  4. Re: audi 80 1992 and vcds
    133 Post(s)
    1987 Post(s)
    You can scan it but you can’t accurately set it up.
  5. Re: audi 80 1992 and vcds
    Jan 2010
    hengoed
    Thanks yet again,
    So in a nutshell its not the same as using the diagnostic plug on my a4 2007, although i know the cable will be different for the audi 80, by that i mean just plugging into the audi 80,s diagnostic plug and printing out the scanned results.
    Anyway thanks for your replies and your valuble time.
  6. Re: audi 80 1992 and vcds
    133 Post(s)
    1987 Post(s)
    To carry out the fault code read is just a mater of plugging in the 2x2 adapter.
  1. audi 80 1992 8c abs controller.
    By merton1973 in forum VCDS - General Questions
    Last Post: 11-04-2011, 09:20 PM
  2. Please Help audi 80 2ltr e 1992
    By ssargent in forum 80 - 90
    Last Post: 12-08-2009, 05:14 PM
  3. Please Help 1992 Audi 80 2.0 issues
    By david1701 in forum 80 - 90
    Last Post: 26-07-2009, 07:23 PM
  4. How To 1992 Audi 80 1984cc B4 engine.
    By trolleyjack in forum 80 - 90
    Last Post: 24-07-2009, 07:10 PM
  5. Mk2 1992 Audi Avant
    By Ayd in forum 100 - 200 - Turbo - 100 S4
    Last Post: 03-12-2007, 10:13 AM
