Thread: Audi A6 avnt final edition 1.9tdi Clutch slipping in 4th and 5th gear
  1. Audi A6 avnt final edition 1.9tdi Clutch slipping in 4th and 5th gear
    Dec 2010
    Carlisle UK
    Just got back from spain and clutch started to slip when revving hard in 4th and 5th ie joing motorway or overtaking. What am I looking at for repair pricewise?
  2. Re: Audi A6 avnt final edition 1.9tdi Clutch slipping in 4th and 5th gear
    It is recommended that you change the Dual Mass Flywheel and clutch, depending on the mileage and age then the slave cylinder as well, so the bast part of £1000. Regards Peter
  3. Re: Audi A6 avnt final edition 1.9tdi Clutch slipping in 4th and 5th gear
    Dec 2010
    Carlisle UK
    Thanks for the reply Peter. Ooof, hefty!! Anyone know why the clutch goes so early compared to other makes. I have driven a range of makes from new to average of 90k without any major part failure like this. From the bit of research I've done it seems this is a common problem with this particular type of clutch (dual mass) Thought Audi were a quality make, not impressed
  4. Re: Audi A6 avnt final edition 1.9tdi Clutch slipping in 4th and 5th gear
    Most modern diesels have DMF and in fact petrol engines as well but it is odd that yours only slips in 4th and 5th, do you not notice the slippage when taking off or in second when you gun it. It can be down to the driving style particularly as it is a heavy car and if you are a bit eager the clutch can spin up due to the torque and slowly wear the clutch out. It may be worth a check underneath to ensure you do not have an oil/clutch fluid drip from the bell housing which may indiscate a contaminated clutch due to either a leaking clutch slave cylinder or a oil seal leak. Regards Peter
  1. 2005 AUDI A6 2.5 TDI Quattro Final Edition 5dr Tip Auto Avant
    By richthevet in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-05-2011, 07:51 PM
  2. Please Help Mk3 Tdi can't select 3rd,4th or 5th gear!
    By djl78 in forum Golf MK3 - 1993 - 1999
    Last Post: 24-09-2010, 09:33 PM
  3. Brief stutter/jerk at 2900rpm in 4th/5th gear
    By DL71 in forum Golf MK3 - 1993 - 1999
    Last Post: 20-11-2009, 02:10 PM
  4. Replies: 0
    Last Post: 20-07-2008, 05:18 PM
  5. power in 4th 5th gear
    By gazza67 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-03-2008, 11:58 AM
