Thread: plastic pipe to intercooler.
  1. plastic pipe to intercooler.
    Mar 2007
    Suffolk
    Hi again,
    I have the common oil weep from this pipe and was wondering if anyone knows if this pipe has an internal o ring before i pull it apart -thought a new ring may cure weep if there is one.
    Mike
    Oct 2005
    Lutterworth
    Yes there is an o-ring and they all weep.........
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
    Mar 2007
    Suffolk
    Cheers Mate,
    As I have tray off as i have just done oil change do you happen to know if I can disconnect the bottom pipe from i/cooler without doing anything else-haynes suggests lockmode/then top hose off then relaese bottom-does it have to be that complicated.Also,i am not likely to do any harm if i pull off pipe and change o ring-am i?
    Regards,once again,
    Mike
    Oct 2005
    Lutterworth
    Don't understand why haynes would say that.
    The bottom i/c hose is a bit fiddly because it's so short.
    Release the clip before you pull the pipe off.
    Passat 1.8SE 1998
  5. Re: plastic pipe to intercooler.
    Mar 2007
    Suffolk
    Cheers mate,
    Same reason they tell you to take rad out to fit electric fan!
    Mike
  1. Fabia vRS Intercooler
    By Lofty86 in forum Fabia
    Last Post: 08-07-2007, 08:33 PM
  2. intercooler or not???
    By BROWN_OWL in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-06-2007, 12:19 PM
  3. Broken plastic cover - windscreen and bonnet
    By magicmillerman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-06-2007, 07:54 PM
  4. Intercooler clean out
    By M4YTY in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-05-2007, 09:06 PM
  5. golf mk 3 exterior black plastic trim
    By mrfunk in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-08-2006, 08:16 PM
