Thread: ESP warning light coming on Passat TDI 130
  1. ESP warning light coming on Passat TDI 130
    Mar 2007
    I Have one of those intermittent problems where my ESP warning light comes on my VW Passat TDI 130 2002 coinsiding with a strange noise from the f/o/s wheel. I've also removed my Belly-Pan and noticed a thudding noise when driving over 65mph also coming from f/o/s wheel area & was just wondering if they are seperate faults or as a result of the ESP light coming on? Anyone help please?
    Coventry
    If the wheels have suitable traction with the road surface, the esp should not come on. Should you skid or slide or lose traction with the road then i would expect the esp to be activated.
    What could cause this wheel to lose traction or contact with the road?
    Shock absorber? Bush of some type? Bearing?
    These are what i would look at 1st.
    Ben
    Jul 2007
    I would also suggest that you check the likes of shocks / bushes etc.
    Sounds as though the esp is working correctly as you maybe experiencing abnormal travel in the suspension, hence the esp light.
    Jul 2007
    I've a 2002 v6 TDE Passat and had an intermittent light come on warning no traction control. I changed the brake switch and have had no further trouble. Hope this helps one problem.
  5. Re: ESP warning light coming on Passat TDI 130
    Mar 2007
    Quote Originally Posted by Robbie Townhill View Post
    Hi;
    Did you find it only seemed to come on with three or more people in the car?
    ps, Thanks for previous reply,didn't notice it first time i posted Q
  6. Re: ESP warning light coming on Passat TDI 130
    check ur abs sensor and o/s/f driveshaft plus the wiring from the abs sensor to the wheelarch liner
    Ed
  7. Re: ESP warning light coming on Passat TDI 130
    Mar 2007
    Quote Originally Posted by Eddie View Post
    Thanks for the info, i'll check them out.
    All the best
  1. Coolant warning light, Passat 1.9 TDI
    By lancspassat in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-01-2010, 12:58 AM
  2. Passat 2001 1.8T - ABS Warning Light On!
    By richard child in forum Passat - Archive Topics
    Last Post: 19-01-2007, 08:40 PM
  3. Passat 2001 1.8T - ABS Warning Light On!
    Last Post: 17-01-2007, 05:38 PM
  4. Warning Light 51 plate Passat
    By 3BG in forum Passat - Archive Topics
    Last Post: 06-12-2006, 08:54 PM
  5. ESP light keeps coming on
    By sparkiUK in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-10-2006, 10:13 PM
