Thread: V6 TDi tuning
  1. V6 TDi tuning
    May 2009
    Cambridgeshire
    Probably been posted a few times, but:
    Are there any physical differences between the V6 TDi in its various stages of tuning??
    Or is it just down to tuning level set by ECU?
  2. Re: V6 TDi tuning
    Jan 2009
    Falmouth, UK
    The 180hp AKE has significant differences to the 150 and 163 variants. Turbo is same but internals are not. Did have a list somewhere but not to hand. Adamss24 is your man for the detail.
    2001 Audi A6 2.5TDI Avant quattro Sport, Celtic Tuning remap, TurboDynamics MD438 hybrid turbo, 3" decatted Longlife stainless exhaust, Bosio Race683 nozzles
    2004 Audi A4 1.9TDI Avant quattro + Superchip
    1988 Yamaha FJ1200
  3. Re: V6 TDi tuning
    May 2009
    Cambridgeshire
    Much appreciated FJTwelve ;-)
    The more I deal with the AKE engine type - the less I like it!
  4. Re: V6 TDi tuning
    london/ UK
    The AKE has stronger rods and pistons with lowered compression ratio, also the gearbox oil is cooled trough the radiator. There are different size nozzles between salloon/avant and so far the allroad uses the biggest nozzles, 3 plunger pump (so it's the avant 180Bhp) and full alloy intercooler for more boost- it needs it because it's a heavy barge ! The allroad also has a fuel cooler but uses the same oil cooler as the rest of the 180Bhp line-up. The turbo fitted to the 150/163Bhp is a Gt 2050 and the one on the 180Bhp is a Gt2052. Different trims on compressor wheels but hot side is the same across the range. The turbo ending in S has been fitted to the sports models and its the best for top speed allthough the allroad one has better pick-up at low revs- ends in F. Gearboxes are also different between models and the allroad one is designed to pull stumps, never tried the low range gearbox but the stock one is only designed for pulling- i know mine does not break a sweat !
  5. Re: V6 TDi tuning
    May 2009
    Cambridgeshire
    WOW!!
    Sounds like they're a bit of a luckybag. . .
    You never know what you get until you get in there.
    :-D
  1. Which TDi best for tuning?
    By parapaul in forum 2.0TDi - Engine
    Last Post: 09-02-2011, 06:23 PM
  2. 2.5 tdi tuning
    By sambo82 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-01-2009, 11:11 AM
  3. Please Help TDI tuning
    By AD02_YNU in forum Golf MK4 - 1999 - 2004
    Last Post: 08-08-2008, 05:42 PM
  4. 1.9 TDi (PD) tuning
    By mobitune in forum Golf MK4 - 1999 - 2004
    Last Post: 02-10-2007, 09:30 AM
  5. Hi and Help for tuning my GT TDI
    By Pigdog in forum New Member Introductions
    Last Post: 22-11-2006, 09:47 AM
