Thread: 1.9 TDi Loss of power
Results 1 to 10 of 11
  1. 1.9 TDi Loss of power
    ICTIS Guest
    Before you all say it - I've replaced it already ! Ok!!! (MAF that is!)
    It's a lot better than it used to be - almost 100% uptime on the turbo - however, occastionally it still drops out and I have to pull over and restart the engine to clear it.
    From experience - what's the next most common item for this??
    My Garage's "code reader" came up with "inlet manifold presure regulating device", but VW don't know wha this is!! Any ideas?
    I've had the error codes cleared out by VW, and will wait to see if this re-appears
    ICTIS Guest
    The loss of power is a little odd. Usually happens when cold, though has once or twice happend after it's been running for quite a while.
    When I accellerate up hill, the turbo cicks in, drops out then kicks in again, all within half a second.
    Once it's dropped out fully, it stays out until I stop and restart the engine.
    Anyone got any pointers please?
    Oct 2005
    Leicestershire UK
    try www.tdiclub.com they know there diseils
    ICTIS Guest
    Thank you
    Dec 2005
    You need to clean your turbo in side or change for another which is clean.http://www.technologie-entwicklung.d...t15-turbo.html Check this web site and you will know what I am talkin about.
    ICTIS Guest
    Thanks for that. Maybe a little above my level but useful non the less
    Looks like a guy with way too much time on his hands!! :-)
    The car seems to be bahaving properly now - and I've not had the turbo drop out at all in the last week. (kiss of death!)
    Nov 2006
    The turbo pressure sensor sounds like the probable cause.
    This is probably the second most common fault to the maf sensor that can cause the type of power loss you are talking about.
    This is usually located on the plastic intake pipe attached to your inlet manifold.
    Hope this helps!
    Regards chrispyg
    Jun 2006
    6 Post(s)
    Is that the N75 valve you are talking about?.
    Canada
    Yes the N75 could be the problem.
    Icitis, do you have the specific numeric code as that will help more.
    Look here at one solution
    http://wiki.ross-tech.com/index.php/17965/P1557/005463
    more codes here associated with charge pressure
    http://wiki.ross-tech.com/index.php/...harge+pressure
    HTH
    Rob
    Jun 2006
    6 Post(s)
    Is it possible for either faulty N75 valve to not show a fault code ?. I ask this as I am experiencing a loss of power in my own car-a Passat TDI Sport. Not had VAG COM done yet but the AA has used their own kit to check for a reading.
  1. 1.9 TDi loss of power
    By richiebarthez in forum Audi A3 - Archive Topics
    Last Post: 14-11-2007, 12:17 AM
  2. Loss of power
    By mia in forum Archive posts
    Last Post: 13-11-2007, 05:06 PM
  3. loss of power
    By sacko17 in forum Touran - Sharan - Caravelle
    Last Post: 13-11-2007, 01:54 PM
  4. Power loss
    By Eugheugh in forum Passat - Archive Topics
    Last Post: 27-03-2007, 06:22 AM
  5. loss of power
    By Lofty in forum 80 - 90
    Last Post: 22-07-2006, 06:28 PM
