Thread: Which Engine Oil is best for 1.9 SDi mk4 Golf
  1. Which Engine Oil is best for 1.9 SDi mk4 Golf
    Jun 2009
    Birmingham, England
    Hi All,
    I would appreciate it if anyone could inform me of the engine oil I require for my Golf m4 1.9 SDi. The VW codes for the oil are VW 505.00, 505.01, 506.00, 506.01, and 507.00 (Wikipedia). So would 5w30 fully synthetic be ok to use.. Please correct me if I am wrong.
    My car has covered 160,000 miles so should I be changing the oil every 5k because my car has high mileage. Your help would be much appreciated.
  2. Re: Which Engine Oil is best for 1.9 SDi mk4 Golf
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Given the high mileage it might be better to use the higher viscosity 505.01 10W-40 oil which is commonly called the P.D. oil . I know yours is not a P.D. engine but the higher viscosity will reduce oil consumption slightly and help maintain the oil pressure. Most Oil outlets will stock this oil and is cheaper than the 507 spec 5W-30. If you do a significant number of short journeys then changing the oil at 5K will be beneficial to engine life but if you do mostly longer journeys where the oil can get up to working temperature for long periods and the engine is in good condition then changing at 10K will be OK.
    At least you don't have any turbo to worry about.
    Skoda Octavia II SE 1.9PD TDI
  1. Question Will an SDi 2000 Polo engine fit a 2003 SDi Octavia
    By genevive in forum Polo - Derby - Lupo - Fox
    Last Post: 06-12-2009, 08:47 PM
  2. MK4 Golf GTI - engine oil Pressure Fault
    By Hectors House in forum Golf MK4 - 1999 - 2004
    Last Post: 06-10-2008, 08:35 PM
  3. Golf SDI Mk4 door lock
    By boatswain in forum Golf MK4 - 1999 - 2004
    Last Post: 24-08-2008, 03:11 PM
  4. golf MK4 GTI 2.0, Which engine oil to use
    By manu in forum Golf MK4 - 1999 - 2004
    Last Post: 08-02-2008, 01:54 PM
  5. turbo on iv golf sdi engine
    By diesel power in forum Archive posts
    Last Post: 24-03-2007, 01:01 PM
