Re: Ko4- upgrade boost problems –
23-07-2011,08:55 PM
If it is dumping boost the DV is at fault. IMO not set up properly?
If it has a rough idle the injection timing is a possible factor in that, and injected quantity, this can usually be adjusted on VAGCOM. You have huge injectors and haven't told your ECU.
as for the power only coming in at 4500rpm. you put a big turbo on an you get lots of lag...however this seems a bit excessive.
Wish i could be more help.
Rich
Headlight Conversion, 2x8000k HID kits, De-cat downpipe, .216 Nozzles Boost Gauge, Colour changed on climate control and all buttons, LED instrument cluster, LED number plate lights, LED rear/brake lights, Lowered 40mm on SPAX springs. Soon to have GT1749VA
