Thread: RNS e
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: RNS e
    Sep 2011
    Thornaby
    Just waiting for my RNS-e to be delivered from E-bay, hopefully it will be a quick and easy install.
    The only issue is finding someone in Teesside with a VAGCOM and correct codes, any suggestions??
    2009 Audi Q5 2.0TDI SE
  2. Re: RNS e
    Sep 2011
    Thornaby
    Just fitted a RNS-e unit off e-bay and placed the GPS behind the glovebox, it reads on average 5-8 satellites. However I am having problems with the Nav refreshing quick enough, it doesn't seem to keep up with the car. I fitted the GPS onto some metal bracing just under the passenger speaker area, could the fact it is on metal be the cause? The GPS does come with a magnetic base.
  3. Re: RNS e
    May 2008
    metal below the antenna is OK but there should be none above it. It should have a clear view of the sky above. (plastic and glass covering it are OK, hence under the dash/glovebox is fine as long as no metal covers it)
    its worth scanning with VCDS as well, that'll ensure all the CAN connections are present and working correctly.
  4. Re: RNS e
    Sep 2011
    Thornaby
    All is well, on the way to OEM Retrofits turned on the Audi Nav and it worked fine??? Even took the route shown on RNS instead of Tom Tom and it is quite good, not as detailed and user friendly as the Tom Tom but works fine.
    Guys at Retrofit coded it for me so now my DIS, BT etc is set up and working fine. Happy days!!
  1. RNS-315 to RNS-510
    By neilsafc in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 19-07-2011, 10:48 AM
  2. Installation of AUDI bluetooth kit for RNS-E RNS
    By 519ryan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-05-2011, 09:14 PM
  3. Rns d to rns e conversion
    By aristidis in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-08-2009, 11:29 AM
  4. Upgrade from RNS-D to RNS-E
    By chrisroffey in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-07-2009, 02:16 PM
  5. rns-d sat nav to rns-e stav nav
    By hockey1980 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-02-2008, 12:19 PM
