Thread: RNS e
Results 1 to 10 of 14
  1. RNS e
    Jul 2010
    birmingham
    Hi all. I have decided that i want to change my origional stereo (symphony 2) for the later rns-e headunit, or any other later headunit like that if advised otherwise . I understand that i will need the antenna for the sat nav and cd, but was wondering if the cd goes in the headunit or in a seperate unit in the boot?
    Also, does the unit need programming to the car? if so, i have vag-com at the garage i work at but have only really used it for eml, abs and airbags so if this is the case, is it relatively easy to programme? thanks for any feedback
  2. Re: RNS e
    May 2008
    The navigation DVD (not CD) goes into the RNS-E. The drive is behind the screen.
    It should be programmed with Vagcom, easy to do, takes 5 minutes.
  3. Re: RNS e
    Sep 2011
    Thornaby
    I am currently considering doing the exact same upgrade. Was it straightforward, did you need any additional wiring/connectors and where did you place the GPS antenna? Thanks
    2009 Audi Q5 2.0TDI SE
    May 2008
    You will need a wiring adapter if you have a B6. The GPS antenna goes under the dash, above the glovebox.
    There are loads of threads on here detailing the process. It's easy.
  5. Re: RNS e
    Sep 2011
    Thornaby
    I have a 2009 (58) B7 S Line Cabriolet, it has the hands free (BT) in the armrest and MFSW. Would this be a simple retro fit and because of the handsfree which works with my i phone can I assume there is already Bluetooth installed?
  6. Re: RNS e
    Aug 2011
    London UK
    Saw this video which can help....
    And this pdf...Installing RNS-E Sat Nav For Audi A4
    And this...RNS-E Installation PDF
  7. Re: RNS e
    Sep 2011
    Thornaby
    Thanks for the replies but I am looking for a simple answer as the guides confuse me, do I need to modify any wiring or is it simply plug and play once the GPS has been fitted?
    Because I have a late model B7 is it simply remove existing double din symphony unit, using existing wiring/connectors, plug in RNS E, install GPS and away we go?
    I understand there may be some coding required.
    Aug 2011
    London UK
    If your car did not come with RNSE you will need wires or adaptation harness that will plug into the existing one to accommodate RNSE, so the answer is Yes wires are needed,
    You will need a gps as well, the are quite cheap, check on eBay.
    Hope this Answers ur Q?
    But have a look at the PDF and check online for more info.
    Rgds
    May 2008
    For a 58 plate B7 you won't need a wiring adapter. Just a GPS antenna and some VAGCOM coding.
    Aug 2011
    London UK
    Thanks for the info Issac, my car came with RNS-E and I have read forums where the adaptation is needed so I assume it might.
  1. RNS-315 to RNS-510
    By neilsafc in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 19-07-2011, 10:48 AM
  2. Installation of AUDI bluetooth kit for RNS-E RNS
    By 519ryan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-05-2011, 09:14 PM
  3. Rns d to rns e conversion
    By aristidis in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-08-2009, 11:29 AM
  4. Upgrade from RNS-D to RNS-E
    By chrisroffey in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-07-2009, 02:16 PM
  5. rns-d sat nav to rns-e stav nav
    By hockey1980 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-02-2008, 12:19 PM
