Thread: Bora leaking. Unable to find location HELP
  1. Bora leaking. Unable to find location HELP
    Feb 2007
    Hi all
    Got a leak at the back left side passenger foot well. When it rains there is no water coming from the back left hand door to make the floor wet.
    Anyone know if this is a common fault, or maybe where it is coming from?
    It is wet on the floor on left hand side at the BACK seats.
    cheers for help anyone.
    Oct 2005
    Could be running from the front to the back - check drainage holes and if you have a sunroof, maybe clear those drains too.
    Feb 2007
    cheers, have no sunroof. Are there any guides with pictures to where abouts these are.
    Not sure if it really is coming from the front as the water is only on the rear passenger footwell floor.
    Oct 2005
    In everything that follows, I'm assuming the Bora is a baby Passat rather than the big Golf it really is!
    I wrote a guide on another forum - it compiles all the useful links.
    Does your Passat leak? (this links to an external website which is unrelated in any way to www.vwaudiforum.co.uk)
    Obviously most wont apply but it gives you an idea of where to start. Pollen filter housing is a common problem across the range.
    I also recall seeing something about a Golf with a leaky window seal on here but I can't find the post
    Feb 2007
    nice one for that link.
    if i find the link i'll post up what the problem WAS so others can give it a go.
    cheers
    Feb 2005
    Selby, North Yorkshire
    Have a look under the boot carpet. If any of the rear light cluster seals, bootlid seal or the boot vent seals (behind the bumper) have perished or moved, you'll get water ingress. It the runs down the boot floor under the back seat and into the footwells, especially if the car is parked at an angle to allow this to happen.
    Well it did on my Bora anyway and it doesn't leak any more!
    Hope this helps.
    Paul
    Oct 2005
    Ah yes, good call that man ^
    Feb 2007
    hi paul jay, there was a little water under the boot carpet yes and the car sits on my street on a angle ( angle being with front facing down road with boot **** high )
    would this cause leaking, will TRY and find these PLUGS you peeps are going on about.
    Feb 2005
    Hi redtony
    It may be one of the rear light clusters which has a leak, the bootlid seal (quite common) or the boot vents. These are located behind the bumper at each side of the car, but you'll only be able to see them if you remove the bumper.
    Try parking the car facing the other way too, this might have the opposite effect!
    You might be able to trace the leak by removing the boot carpet, dusting the boot floor with talc and then applying a hose, or just wait for it to rain - it won't be long!
    Hope this helps mate.
    Paul
  1. where do i find.....
    By Dozz in forum VCDS - General Questions
    Last Post: 24-06-2007, 08:00 PM
  2. has anybody bothered to find out........
    By Dozz in forum Chat - Anything with wheels
    Last Post: 09-06-2007, 12:42 AM
  3. Need a part I can only find in UK.... thanks for looking.
    By deephouse in forum Audi A4 - Archive Topics
    Last Post: 05-02-2007, 08:11 PM
  4. Passat unable to open door
    By Fibreron in forum Archive posts
    Last Post: 18-11-2006, 06:20 PM
  5. Insurance Co cant find my car
    By Passat130 in forum Passat - Archive Topics
    Last Post: 28-07-2006, 02:27 PM
