Thread: Automatic window/ sunroof closure.
Results 1 to 10 of 14
  1. Cool Automatic window/ sunroof closure.
    S.E / Kent
    Hi guys,
    Has anyone tried to use the KVW100 to enable the automatic closure or open of the passat windows/ sunroof? I got this info on this link http://www.vagproducts.co.uk/pages/p...rt/kvw1003.php.
    Was the down load successfull?
    redman.
    Jul 2007
    Bradford on Avon
    I have the KVW100 from vagproducts and it installs verrrry easily (following the instructions) and functions as the maker describes.
    If you keep the dongle you can easily uninstall the update if you need to.
    Its very freaky to watch your sunroof and windows close as you lock the car!
    A, A
    And me:
    Just another B7 Estate
    Apr 2007
    hey guys sounds good how does it actually work do you have a seperate remote or just your existing one and do the windows go up and down every time you lock/unlock the car or do you hold the button down, also is it a one time use or can you use it on more than one car??
    Jul 2007
    Bradford on Avon
    You keep your normal plip and the unit is only capable of updating one vehicle.
    If you look at the video in the post above you can see that the windows can be rolled up and down.
    For detailed information check out http://www.szkvw.com
    Verwood, Dorset
    Surely this can be acheived without paying £25 for a "One shot" reprogrammer.. Using a laptop via the OBD port there must be some software somwhere that can do that? Anyone throw any light on this??
    Dec 2006
    Wiltshire
    I think this can be programmed using a VAGCOM - I'm not 100% sure - perhaps someone else can confirm this?
    A6 (2007)TDi SE Avant
    Gone but not forgotten - A4 2.5TDi Avant, Imola Yellow S3 , Golf VR6 Highline
    A, A
    Not through VAG COM, but through EEPRON programming IIRC.
    Oct 2005
    If you had an Audi then yes, VAG-COM would work.
    Why not get yourself an autowindow module - I have one that shuts/vents/opens all my windows and illuminates the headlights etc
    http://www.autowindow.com/
  10. Re: Automatic window/ sunroof closure.
    Jul 2007
    Bradford on Avon
    I like that autowindow product, but I do remember seeing information elsewhere "vwvortex?" that gave some details about directly programming the features but did not seem conclusiven as to the result...
  1. mk3 sunroof
    By wilmot in forum Golf MK3 - 1993 - 1999
    Last Post: 17-09-2007, 04:29 PM
  2. Total Closure Via Remote
    By vw_jack in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-06-2007, 11:08 AM
  3. Sunroof
    By san in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 19-02-2007, 03:04 PM
