Thread: quatro 4wd system
Results 1 to 10 of 12
  1. quatro 4wd system
    Jul 2007
    hi, can anyone give me any info on the audi s2 (awd) quatro system,
    what is the torque split? 50/50?
    what make r the diffs?
    are the diffs open? or lsds?
    what hp can the gearbox take? can it take big power? and 6-700rpm launches?
    any info on the audi awd system would be much appreciated. thanks
    Oct 2005
    Lutterworth
    Why not start with Wikipedia and build from there....
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
    Gwent
    The torque split is 50/50 but varies as necessary to obtain grip. The centre diff is a torsen, the rear is manual locking, which disengages at 15mph.
    The gearboxes stand up to a lot of power, but from what I've read, they do not like being shock loaded when transmitting a lot of power.
    E.g. on a smooth dragstrip, 500hp might be fine, but if there was a bump that caused wheelspin then grip is re-established, 350hp might be enough to break something. 034efi have a highly modified 20v turbo that puts approx 750 hp to the wheels through a modified 6 speed quattro box. They were using standard 5 speeds up to approx 500 wheel hp, but breakages started ocurring.
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
    Jul 2007
    excellent just the info i needed thanks scotty. dont suppose you know what modyfied audi 6 speed box they used? ie what audi its off?
    also does anyone know what sort of hp the audi TT 4wd sytem will support? ive read about a shirocco owner using this system and running 10 sec qtrs.
  5. Re: quatro 4wd system
    Gwent
    It's an 01E, comes in the RS2 and 2.7 biturbo S4. The gears and I think the shafts are cryogenically (is that a real word?) treated.
  6. Re: quatro 4wd system
    Jul 2007
    cool, thanks for the info.
  7. Re: quatro 4wd system
    Yorkshire
    The rocco blew up on Sunday, I saw it.
    The original UR quattro box will take more power than either S2 gearbox.
    My mate runs the Dubweiser golf and that puts out 648bhp at the wheels with one fitted.
  8. Re: quatro 4wd system
    Jul 2007
    Quote Originally Posted by S2AVANT View Post
    cool, thanks for that mate, what model uses the ur 4wd gearbox?
    also is the dubweiser golf using stock diffs? and driveshafts? does he ever break any on the drivetrain? cheers
  9. Re: quatro 4wd system
    Yorkshire
    The UR is a model, as in UR quattro the original 4WD rally car.
    He has a custom made input shaft which costs a grand as he was always breaking it when he got traction going into forth. He has not broken anything since having that made.
  10. Re: quatro 4wd system
    Jul 2007
    kk, thanks mate. how easy are these box`s and diffs ect to get hold of? and what sort of money they worth?
  1. A6 2.tdi Quatro 53 Plate
    By a6sajid in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 11-06-2007, 09:23 PM
  2. Not sure what CD goes in my RNS Navigation system.
    By jasear in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-04-2007, 11:26 AM
  3. 1999 audi tt Quatro 180 55,000 miles
    By vazlb in forum TT - 8N Forum - 1998 - 2006
    Last Post: 28-04-2007, 12:43 PM
  4. A4 avant 2.5 tdi quatro steering noise, air con, door handle
    By tkboy in forum Audi A4 - Archive Topics
    Last Post: 19-04-2007, 11:00 PM
  5. A4 avant 2.5 tdi quatro steering, air con, door handle
    By tkboy in forum Chat - Completely Off Topic
    Last Post: 20-11-2006, 03:05 PM
