Thread: manual gearbox fluid change
Results 1 to 10 of 14
  1. manual gearbox fluid change
    Oct 2010
    Middx, UK
    My gearchange feels a bit 'clunky'. Car has done 101k and you can hear the gear change (at low speed hence less road noise). I'm thinking of draining and refilling so here come my questions!:
    1. is there any special fluid to use? Can VW tranny fluid be used?
    2. how much?
    3. Where is the filling point?
    4. drain plug is likely to be on the side somewhere?
    When i drained the Corrado fluid it was from the side drain hole and filled by removing the selector tower and filling via a funnel & hose, about 2 litre iirc.
    TIA
    A4 B6 S-line, 90k miles
    Bonny Scotland
    Best post up your gearbox code so folks can help with oil grades & fill point.
    You will most likely need to get the correct drive bit for the drain & fill plugs as Audi like using non standard patterns for giggles.
    Lastly, check the fill plug isn't ceased BEFORE draining the old fluid to save embarrassment.
    Frank
  3. Re: manual gearbox fluid change
    Oct 2010
    Middx, UK
    thanks frank. where is the gearbox code printed? engine code is BEX
    Bonny Scotland
    Should be on the build-sticker in the spare wheel recess and inside front cover of the service manual.
    I think the transmission codes take the form of 2 numbers and a letter but am prepared to stand corrected.
    Frank
  5. Re: manual gearbox fluid change
    Oct 2010
    Middx, UK
    gearbox cod is HES and according to ETKA uses the same fluid as the Passat. Just had a look in the bay but really cant see how or where to fill it from. Also, is htere any way to check the level, it may just need to be filled up slightly. Is there an issue if too much fluid is filled in the gearbox?
  6. Re: manual gearbox fluid change
    Feb 2009
    Glasgow UK
    Interesting......my A6 has covered 84k miles and although my gear change isn't exactly clunky, just maybe I'm thinking not quite as smooth as it once used to be. This is something I considered myself around 6 months or so ago, but never got round to, still consdering it, so I'll be tuning in here to see how it goes.
    I'm looking forward to a complete write up with pics showing / explaining the entire procedure in great detail.....It'll be a nice add on to the "How to's"...
  7. Re: manual gearbox fluid change
    Oct 2010
    Middx, UK
    would Castrol smx-s be suitable? Seems to fulfill the VW criteria for fully synth, GL4 75w90. TIA
  8. Re: manual gearbox fluid change
    May 2008
    darlington
    Only use genuine audi gearbox oil.
  9. Re: manual gearbox fluid change
    Oct 2010
    Middx, UK
    Any reason why White Akita, assuming that some alternatives are compliant? Have there been any specific issues with using others? TIA
  10. Re: manual gearbox fluid change
    May 2008
    darlington
    I have tried several fluids claiming to be the same spec and the gearbox was still notchy.
    i then put in genuine fluid and it was like butter.
  1. A6 Manual transmission fluid change??
    By JimC64 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-12-2013, 05:38 PM
  2. Manual Gearbox Oil Change Interval
    By vsheremeti in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-02-2011, 09:52 PM
  3. Gearbox Oil Change 5-spd manual
    By ike in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-05-2010, 08:23 PM
  4. Question can you change the oil in a manual gearbox?
    By N47HAN in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-01-2009, 09:46 AM
  5. 1997 A4 1.9 Dti manual gearbox change or repair
    By jeremy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-02-2008, 07:52 PM
