Thread: Having trouble finding a fuel temperture sensor on a t4 2.5 tdi transporter? Can anyone help
Results 1 to 8 of 8
  1. Having trouble finding a fuel temperture sensor on a t4 2.5 tdi transporter? Can anyone help
    Jul 2011
    Peterborough
    Hi i have recently acquired a Transporter which is currently stuck in limp mode, i scanned the vehicle using a snap one modus scanner and i got coolant temp sensor and also the code:
    00539- Fuel temperature sensor- G81 open circuit/short with power intermittent.( presuming the sensor needs replacing)
    I have replaced the coolant temperature sensor and is all working fine , i have tried locating the fuel sensor but cannot seem to find this, Does anyone now where it is located and if so is it easy to access.
    Details of vehicle the engine is in:
    Volkswagon transported
    2.5 tdi
    1997 plate
    T4 model
    If anyone could help me or send me a simple diagram where it is located. Thanks in advance
    If this topic is in wrong place , please can you move as couldn't find a suitable topic section.
  2. Re: Having trouble finding a fuel temperture sensor on a t4 2.5 tdi transporter? Can anyone help
    134 Post(s)
    2007 Post(s)
    The fuel temperature sensor G81 is in the fuel pump, the part number is 028 906 040 C and they cost just under £20. Officially VW say that the pump has to be replaced to change the sensor BUT if you have the special Bosch 0 986 612 605 D socket tool AND you know how to rest the Injected Quantity in Measuring blocks 001 zone 2, then you can change the sensor.
  3. Re: Having trouble finding a fuel temperture sensor on a t4 2.5 tdi transporter? Can anyone help
    Jul 2011
    Peterborough
    I have changed the fuel temperture sensor in the top of the pump but cant seem to get fuel to the injectors is this because it needs recoding to pump? upon scanning with a snap on modus scanner it puts no codes up, where do i go from here?
  4. Re: Having trouble finding a fuel temperture sensor on a t4 2.5 tdi transporter? Can anyone help
    134 Post(s)
    2007 Post(s)
    You have lost me? Have you changed the sensor since your post yesterday?
  5. Re: Having trouble finding a fuel temperture sensor on a t4 2.5 tdi transporter? Can anyone help
    Jul 2011
    Peterborough
    I have replaced the sensor now and doesnt seem to start , do the parameters have to be reset or is it a simple case of air in the fuel lines?
  6. Re: Having trouble finding a fuel temperture sensor on a t4 2.5 tdi transporter? Can anyone help
    134 Post(s)
    2007 Post(s)
    You have to get the cover back on as close as possible but getting them to start after can take some serious cranking. Give it a gentle sniff or two.
  7. Re: Having trouble finding a fuel temperture sensor on a t4 2.5 tdi transporter? Can anyone help
    Jul 2011
    Peterborough
    ok thanks , i'll retry today with a fresh battery ,
    If people didnt know you can flip you front end down by undoing the intercooler bolts and 2 13 bolts which enables the front to flip down on its hinges. this then makes the top of the pump easily accessible
  8. Re: Having trouble finding a fuel temperture sensor on a t4 2.5 tdi transporter? Can anyone help
    134 Post(s)
    2007 Post(s)
    VW call it the “service position”.
  1. Please Help Transporter Fuel Temp Sensor
    By Olow in forum The Commercial Range
    Last Post: 28-09-2009, 02:47 PM
  2. VW Transporter trouble
    By burygas in forum The Commercial Range
    Last Post: 11-03-2009, 12:35 AM
  3. finding iat sensor
    By Nessy Darwin in forum Golf MK4 - 1999 - 2004
    Last Post: 31-01-2009, 06:08 PM
  4. Transporter T4 2.5 tdi fuel economy?
    By Clunk in forum Archive posts
    Last Post: 20-11-2007, 03:16 AM
  5. temperture sensor location A4 B6 1.8t
    By ramong2007 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-10-2007, 02:52 PM
