Thread: Cambelt change
Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. Re: Cambelt change
    #21
    Mar 2007
    coventry
    huummmm ok fiver and a pint then
    no matter how you try you always come back to what you first started
  2. Re: Cambelt change
    #22
    Jul 2007
    Matlock
    It probably will if you stay away from the ******** mate!
    £320 quoted for belt, rollers and pump by the way at JBS Autodesign in Chesterfield.
  3. Re: Cambelt change
    #23
    Mar 2007
    coventry
    ask dave in his audi a4 cab 2,5 tdi on how many miles a cambelt will do and thats his answer
    gook luck
  4. Re: Cambelt change
    #24
    Jul 2007
    Matlock
    Hi MARDS8,
    just had the belt,rollers water pump and coolant changed at JBS Autodesign in Chesterfield using VAG parts for £320.
    Thanks again for your advice!
  5. Arrow Re: Cambelt change
    #25
    Mar 2007
    Greater Manchester
    H'mm, £320 seems a bit steep (though cheap compared to *******s). I'm assuming JBS Autodesign is the type of place that does upgrades and mods etc..
    I've had a quote from my local garage who does my MOT and Servicing. He charges £35/hr labour and said it was upt 2hr job including rollers and water pump. The parts I'm guessing will propbably cost upto £75. So I would be looking at £150 for a cambelt change.
  6. Re: Cambelt change
    #26
    Bristol
    It also depends if you have to remove the front end or not to get at the cambelt !!!!
  1. cambelt change?
    By AJ84 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 15-05-2007, 08:15 PM
  2. Cambelt Change
    By wg100 in forum Golf MK2 - 1984 - 1992
    Last Post: 30-03-2007, 09:16 PM
  3. cambelt change 2.5v6 tdi
    By mer in forum Passat - Archive Topics
    Last Post: 30-12-2006, 06:20 PM
  4. cambelt change on tdi
    By HOVISVW in forum Chat - Completely Off Topic
    Last Post: 14-10-2006, 11:23 AM
  5. cambelt change interval
    By jezzaxt in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-09-2006, 10:09 AM
