Thread: Cambelt change
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. Question Cambelt change
    Jul 2007
    Matlock
    Hi, i have a 2003 Passat tdi PD100 which has done 32000 miles and will be four years old in September.
    Can anyone tell me if i should change the cambelt at four years or wait a little longer?
    Mar 2007
    coventry
    i think they are good for three years or 60k miles whichever comes first
    i hope this helps if you are in doubt then ask main dealer for advise but i recomed to get changed buy a local garage
    rich...
    Jul 2007
    Matlock
    Quote Originally Posted by golf tdi 02 View Post
    rich...
    Thanks for that
    just to correct... its 60 k or 4 years, whichever comes first, therefore yours is due mate
    Jul 2007
    hi new member a mate of mine looked in his book of cambelts and it states the cam belt change should be done at 120k the vw user manual states 110k or 180km
    Quote Originally Posted by Gurdeep View Post
    ignore that though.... various technical bulletins have been released prior to the printing of the manual.
    current VW advice is 60k or 4 years, whichever comes first.
    leaving it until 120k is an extremely risky thing to do
    134 Post(s)
    2007 Post(s)
    VAG have now changed their mind and it is 4 years without exception, mileage being immaterial unless it exceeds 60K in four years in which case mileage comes first. Please don't cut corners, have the water pump replaced (a genuine unit makes good sense as if it fails in warranty, VW will do the work for free) and make sure a top quality kit is used such as from INA or genuine. If your engine has the friction damped adjuster, the job is much easier tan the pain in the bottom hydraulic type where it can take a hour just to achieve a perfect 4-mm tensioner gap.
    Mar 2007
    coventry
    in my opinion id rather change a belt at 3years old than ooppss your belt has just snapped at four years.
    i drive my car hard and think that three winters are long enough for a belts life including the tensioner and the roller.
    a cambelt change was done on a 54 plate golf on friday the miles on the clock was 30k it was a precautionary change.
    as the old belt was taken off the roller fell to bits the belt was keeping it going so you can make your own mind up
    only my opinion
    rich...
    no matter how you try you always come back to what you first started
    134 Post(s)
    2007 Post(s)
    I agree with changing the belt more often on a hard driven PDTDI as the belt has a lot of load applied to it and the tensioners are notorious for failure but we have to draw the line somewhere when it comes to advising customers, if they ask for a job to be done that’s a different matter. If we started recommending a belt change at three years, regardless of mileage, people would accuse us of trying to rip people off so we stick to the new intervals. One that did upset me though, last week I had to recommend we changed the belt on a 99 Octavia 1.4 owned by a really nice elderly gentleman, a pensioner, as it had never been done. What upset me was the car had done eight thousand miles from new and the belt/tensioner/water pump were perfect when removed. The only reason we did it was he was shown the new VAG recommendation leaflet and agreed that if we didn't recommend it, and it then failed, we would be responsible for the damage/
    Jul 2007
    Matlock
    Just spoken to my local main dealer asking if they changed my cambelt for a new one after changing the water pump at 14K Dec 2005 after an underheating problem, and they told me they had not.
    Even though it was a warranty repair you would have thought that they would have given me the option of paying for a new belt which would have saved me the £360 they want for doing the job now.
  1. cambelt change?
    By AJ84 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 15-05-2007, 08:15 PM
  2. Cambelt Change
    By wg100 in forum Golf MK2 - 1984 - 1992
    Last Post: 30-03-2007, 09:16 PM
  3. cambelt change 2.5v6 tdi
    By mer in forum Passat - Archive Topics
    Last Post: 30-12-2006, 06:20 PM
  4. cambelt change on tdi
    By HOVISVW in forum Chat - Completely Off Topic
    Last Post: 14-10-2006, 11:23 AM
  5. cambelt change interval
    By jezzaxt in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-09-2006, 10:09 AM
