Thread: Rear reading reading lights not working
  1. Rear reading reading lights not working
    Sep 2009
    Milton Keynes, UK
    Have just noticed that the rear ceiling reading lights on my A4 don't work. Also the green light on the dash that shows the side lights are on doesn't work either. Could the two be related and would you know how to fix them?
    Many thanks in advance.
  2. Re: Rear reading reading lights not working
    Jul 2010
    Bracknell
    The rear light is probably just a blown bulb. Easy to change as the fitting just clips in.
  3. Re: Rear reading reading lights not working
    warp_speed Guest
    Quote Originally Posted by Daftbrush View Post
    Not sure about your first issue, have you checked the fuse? I've also noticed that the green dash board light doesn't display on my car when the lights are on, but I think it must be something different in the B7, because my B6 used to light up. Think I remember there being configuration code you can set somewhere to get it to light, hopefully someone else with more knowledge will be along to fill in the blanks.
  4. Re: Rear reading reading lights not working
    Norwich
    On the B7 the sidelights on indicator turning green is on the light switch
  1. Map Reading Lights
    By black999 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-04-2011, 10:33 AM
  2. Question Rear reading lights in MK5 GTi?
    By TimS996 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-01-2011, 11:17 PM
  3. Replies: 1
    Last Post: 04-11-2009, 12:41 PM
  4. outside temperature reading '- - -'
    By abble in forum Golf MK4 - 1999 - 2004
    Last Post: 11-06-2008, 10:17 AM
  5. New to Reading Berks
    By The Boss in forum New Member Introductions
    Last Post: 04-03-2007, 11:04 PM
