Thread: Polo with azq 3 cyl engine wont start
Results 1 to 10 of 10
  1. Polo with azq 3 cyl engine wont start
    BIGBADBORA Guest
    My polo wont start. Ive just replaced the timing chain, Bought the full kit from vw. Ive replaced the coil packs. still wont fire up. The engine is timed up correctly using the pins. Ive got good compression on all clyinders. Does anyone have any suggestions.
  2. Re: Polo with azq 3 cyl engine wont start
    131 Post(s)
    1976 Post(s)
    You need a fault code read and to study the measuring blocks to make sure you are getting an rpm pulse from the crank speed senor.
  3. Re: Polo with azq 3 cyl engine wont start
    BIGBADBORA Guest
    Cheers crasher, Ill add the fault scan to this. not sure how to check for the rpm pulse.
    Chassis Type: 9N - VW Polo
    Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
    VIN: WVWZZZ9NZ4Y040254 Mileage: 160460km/99705miles
    Address 01: Engine Labels: Redir Fail!
    Part No: 03E 906 033 L
    Component: 1.2l/4V SIMOS3 00HS4726
    Coding: 00071
    Shop #: WSC 00788
    VCID: 2952E7DBF969
    WVWZZZ9NZ4Y040254 VWZ7Z0B6307370
    1 Fault Found:
    17925 - Power Supply Relay for ECU (J271 or J363): Electrical Malfunction
    P1517 - 35-10 - - - Intermittent
    Readiness: 1110 0101
    Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS2.lbl
    Part No: 6Q0 907 379 L
    Component: ABS FRONT MK60 0101
    Coding: 0001097
    Shop #: WSC 00788 785 00200
    VCID: 46884C674837
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
    Part No: 6Q0 820 045
    Component: Klimaanlage X0840
    VCID: EAD058D7BCEF
    1 Fault Found:
    01596 - Motor for Outside/Recirculated Air Flap (V154)
    30-00 - Open or Short to Plus
    Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
    Part No: 6Q1 937 049 C
    Component: 00 BN-SG. 1S33
    Coding: 25742
    Shop #: WSC 00788
    VCID: 3B7E2D9303F5
    5 Faults Found:
    00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
    28-10 - Short to Plus - Intermittent
    00906 - Horn (H1)
    00975 - Heated Rear Window (Z1)
    01598 - Drive Battery Voltage
    07-10 - Signal too Low - Intermittent
    27-00 - Implausible Signal
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 605 K
    Component: 0L AIRBAG VW51 0P 0008
    Coding: 12364
    Shop #: WSC 00788
    VCID: 2C5C1ECFF69B
    1 Fault Found:
    00532 - Supply Voltage B+
    Address 17: Instruments Labels: 6Q0-920-xxx-17.lbl
    Part No: 6Q0 920 900 H
    Component: KOMBI+WEGFAHRSP VDO V17
    Coding: 01431
    Shop #: WSC 00000
    VCID: 336E05B32BA5
    No fault code found.
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: 11 GATEWAY CAN 1S33
    Coding: 00014
    Shop #: WSC 00788
    VCID: F0E44ABF9A33
    Address 44: Steering Assist Labels: 6Q0-423-156.lbl
    Part No: 6Q0 423 156 S
    Component: LenkhilfeTRW V260
    Coding: 10140
    Shop #: WSC 00788
    VCID: 3F86598317ED
    Address 46: Central Conv. Labels: 6Q0-959-433.lbl
    Part No: 6Q0 959 433 H
    Component: 1R Komfortgerát 0002
    Coding: 00067
    Shop #: WSC 00788
    VCID: 40845A7F6A13
    Part No: 6Q1959801A
    Component: 1R Tőrsteuer.FS TFK 0004
    Part No: 6Q1959802A
    Component: 1R Tőrsteuer.BF TFK 0004
    3 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
    53-10 - Supply Voltage Too Low - Intermittent
    01331 - Door Control Module; Driver Side (J386)
    01332 - Door Control Module; Passenger Side (J387)
    Address 56: Radio Labels: 1J0-035-15x-56.lbl
    Part No: 6X0 035 152 B
    Component: Radio BNO 0006
    Coding: 00001
    Shop #: WSC 00788
    VCID: 30640ABFDAB3
  4. Re: Polo with azq 3 cyl engine wont start
    131 Post(s)
    1976 Post(s)
    Will that engine fault code clear or does it keep coming back?
  5. Re: Polo with azq 3 cyl engine wont start
    BIGBADBORA Guest
    It keeps coming back, However ive since purchased a compression tester as i didnt think it had compression. turns out 0 on all clyinders. Think the bloke i had out ran a mile and told me it had good compression. open heart surgery. bent valves i suspect. thanks for the reply ill post once the heads off.
  6. Re: Polo with azq 3 cyl engine wont start
    Bristol
    Is the chain still on right? They do jump on the 3-cyl 1.2s apparently, something to do with low oil pressure.
    2002 Polo 9n 1.2 65PS. Basic but it's better than the train!
  7. Re: Polo with azq 3 cyl engine wont start
    BIGBADBORA Guest
    Here is the latest update on the polo. 6 bent valves. Ive changed them and am in the process of putting it back together. Here is some of the valves i cant believe they didnt snap.bent valves.jpg
  8. Re: Polo with azq 3 cyl engine wont start
    BIGBADBORA Guest
    Polo now back running perfectly. Thanks too all who replied to this. Going to look For a newer vw this weekend. Does anyone have any suggestions on the most reliable cheap run about? Polo or Golf diesel?
  9. Re: Polo with azq 3 cyl engine wont start
    Bristol
    Heard good things about the 1.4 and 1.9 TDIs, as long as they're looked after. Mass Airflow sensor and, unfortunately, the turbos, seem to be the major cause of angst on the forums.
  10. Re: Polo with azq 3 cyl engine wont start
    BIGBADBORA Guest
    The polo is now gone from my stable. Bought a Renault modus probably out of the frying pan and into the fire. Havent given up on Vws still got the mk4 golf tdi and a skoda octavia vrs. Mrs liked the look of the Renault. Thanks to all who replied.
  1. Please Help Polo wont start.
    By BIGBADBORA in forum Polo - Derby - Lupo - Fox
    Last Post: 18-05-2011, 01:55 PM
  2. Polo AZQ label file
    By pezza371887 in forum VCDS - Help Requests
    Last Post: 18-01-2011, 09:58 PM
  3. 04 Polo 3 cyl engine light
    By Prontocold in forum Polo - Derby - Lupo - Fox
    Last Post: 04-08-2009, 10:50 AM
  4. Question Questions on our 1.2S, AZQ engined, 2002 Polo
    By JUV in forum Polo - Derby - Lupo - Fox
    Last Post: 11-02-2009, 01:33 PM
  5. Polo wont start
    By nige61 in forum Polo - Derby - Lupo - Fox
    Last Post: 12-04-2007, 10:23 PM
