Thread: T5 2.5 AXD Engine. Location of coolant temp. sensor.
  1. T5 2.5 AXD Engine. Location of coolant temp. sensor.
    Hello.
    I've seen from other post that this might be behind the oil cooler. This is not easy to get at on my Shuttle with AC etc. Can any one confirm that the temp sensor is behind the oil cooler before I start stripping the front off, not the 10 minute job I was hoping for!!
    Thanks.
  2. Re: T5 2.5 AXD Engine. Location of coolant temp. sensor.
    Jul 2011
    Peterborough
    Presuming it is in a similar place to the t4 , it is in the hose want comes of the block, easily accessible from underneath just behind the back of the air con pump.
  3. Re: T5 2.5 AXD Engine. Location of coolant temp. sensor.
    Hello.
    The engine in the T4 is different.
    I found the sensor in the end. It's in the block in line with number two cylinder, under the inlet manifold, not easy to get at!!
    Thanks for the reply.
  1. Please Help coolant temp sensor location
    By arman123 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-06-2011, 10:43 AM
  2. a3 coolant temp sensor location
    By woody650 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 17-04-2010, 12:34 PM
  3. Coolant Temp sensor location
    By Saturn in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-12-2009, 07:41 PM
  4. IAT (Intake air temp) and Coolant Temp sensor location
    By yep.its.jay in forum Audi A3 - Archive Topics
    Last Post: 16-03-2009, 10:33 PM
  5. A4 B6 1.8T coolant temp sensor location?
    By lwodrumm in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-12-2007, 05:41 PM
