Thread: PLEASE Someone HELP !!! a3 8p rear hub bearing questions.
Results 1 to 9 of 9
  1. PLEASE Someone HELP !!! a3 8p rear hub bearing questions.
    Hi all,ive ordered 2 rear hub/bearing off e-bay and in a few days (mon/tue) they should arrive.
    A3 TDI SPORTBACK 30MM REAR HUBS.
    I want to know the rear hub torque settings?
    well to be honest i rang an audi dealership and they have told me its 200 Nm then once thats done tighten it a further 180 degrees.
    Is this about right? it sound quite tight,il be using a normal Torque Wrench,and new bolts as ive been told they must be renewed.
    To be honest i thort i may snap the bolt tightening it that much ,thort id just double check with you guys???
    Il have to tighten up with a bar i think just to put some pressure on it.
    any other advice you can give me would be apreciated very much.
  2. Re: PLEASE Someone HELP !!! a3 8p rear hub bearing questions.
    Oct 2005
    Moved from How To (read) section to A3 8P section.
  3. Re: PLEASE Someone HELP !!! a3 8p rear hub bearing questions.
    cheers. Just to update ive been told by alot of mechanics just to tighten it up,no need to torque it. This ok? what would you guys do?
  4. Re: PLEASE Someone HELP !!! a3 8p rear hub bearing questions.
    Dec 2007
    8 Post(s)
    Quote Originally Posted by vw754 View Post
    Try to get more info. If tapered bearings are fitted and you tighten too much they could lock up and possibly cause accident.
    Regards,
    Michael.
  5. Re: PLEASE Someone HELP !!! a3 8p rear hub bearing questions.
    HUB BEARINGS COMPLETE HUB
  6. Re: PLEASE Someone HELP !!! a3 8p rear hub bearing questions.
    Aug 2007
    Newquay, Cornwall
    If you tell me the year, engine size and model, I can tell you the torque setting.
    Andy
    2010 Passat 1.6 TDi Blue Motion, Ebony Black.
  7. Re: PLEASE Someone HELP !!! a3 8p rear hub bearing questions.
    131 Post(s)
    1973 Post(s)
    You need a very strong ¾” drive M18 XZN key, my first one snapped as I was tightening the hub up and it left me in a crumpled head on the floor. The tightening torque is extremely high, 180 Nm + ½ turn (180°) for cars with a steel carrier.
  8. Re: PLEASE Someone HELP !!! a3 8p rear hub bearing questions.
    Quote Originally Posted by ford776 View Post
    Andy
    ive found out its 200Nm + 180 degrees mines 2005 2.0 tdi and im sure its the 30mm bearing
  9. Re: PLEASE Someone HELP !!! a3 8p rear hub bearing questions.
    just to let you all know..the old bearing came off in my hand without a puller,both of them,one of the bearings fell out the hub aswell.
    The new hubs were both replaced they slid on the shaft then the bolt was torqued to spec......nice and quiet now.
    had to use the old dust covers on the hubs some how never got any new ones with mine ( the metal plate/cover that covers the bolt......shold be ok anyway) i had some high temp grease( in the garage) ....should i have filled the hub with that aswell?
  1. 1999 A6 Quattro rear hub to a 1991 A4 Quattro rear hub?
    By sackie in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-02-2011, 11:41 AM
  2. Rear bearing help, Had to grind hub off!!
    By workhorse in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-10-2010, 12:06 AM
  3. Question Wheel Bearing/ Hub ???
    By belfastmark in forum Golf MK4 - 1999 - 2004
    Last Post: 01-07-2010, 01:09 PM
  4. Mk3 Golf - Front Wheel Bearing Hub Torque Settings
    By BugBit in forum Golf MK3 - 1993 - 1999
    Last Post: 01-02-2008, 01:32 PM
  5. A4 Hub/Bearing Bolt-On
    By ChrisFurlong in forum Audi A4 - Archive Topics
    Last Post: 30-08-2007, 06:55 PM
