Thread: Front end clunk- steering or suspension
  1. Front end clunk- steering or suspension
    Jul 2006
    Bloxham, Oxon
    My 1996 A6 Avant 1.9 TDI has developed a noticeable clunk from the front end, mainly when turning the steering, especially noticeable when first pulling away. Sounds like it's coming from the left side, but difficult to be certain.
    First I thought it was the strut-top spring bearing, but I replace that to no avail.
    Just today replaced both front ARB inner bushes where it mounts on the sub frame, no difference though.
    Not so long ago, I replaced the lower arms and damper inserts, now planning to replace ARB outer bushes where fixed to lower arms.
    Just can't work out what's causing it, on inspection I can't find any play anywhere.
    Any ideas welcome !
  2. Re: Front end clunk- steering or suspension
    Jul 2010
    battle
    My A4 does the same and my dads a6 also does this, normally only when going over a bump, its the front drop links, they are very cheap to buy, about a tenner I think.
    I find myself its just easier to turn the stereo up, as I'm too lazy to change mine. lol
  3. Re: Front end clunk- steering or suspension
    Jul 2006
    Bloxham, Oxon
    Guys, replaced the outer ARB bushes in the lower arms, no change. Any ideas where to go next ? (ref previous post, there are no drop links on this car)
  4. Re: Front end clunk- steering or suspension
    Jul 2010
    battle
    I had mine changed last week on my car, and on the bill they are called link rods, the garage said you can buy a kit with the bolts, and now its lovely and quiet.
    I wouldn't think it would be much different, my A4 is a 1995 1.6, but my father has a 1994 A6 avant and it makes an identical clunk
  5. Re: Front end clunk- steering or suspension
    Jul 2006
    Bloxham, Oxon
    OK it's a problem with the road spring, possibly the top bearing is not turning properly, which is odd because I changed the bearing last year. I'm going to have to remove the strut to take a look at it.
    Looks like quite a big job.
  1. Question front suspension/steering again
    By autotrans in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-10-2010, 01:16 AM
  2. front squeak, clunk and a woosh
    By rutlandfsi in forum Golf MK5 - 2004 - 2009
    Last Post: 17-06-2009, 10:32 PM
  3. Suspension Clunk
    By Pipeline in forum Bora - 1998 - 2005
    Last Post: 15-02-2009, 03:32 PM
  4. mk4 golf front clunk on full lock then front rattle over bumps
    By jwexqm in forum Golf MK4 - 1999 - 2004
    Last Post: 30-05-2007, 11:04 PM
  5. front end clunk
    By jbdmax in forum Bora - 1998 - 2005
    Last Post: 25-10-2006, 03:01 PM
