Thread: Injector Failures - Possible recall
Page 35 of 67 FirstFirst ... 25333435363745 ... LastLast
Results 341 to 350 of 661
  1. Re: Injector Failures - Possible recall
    135 Post(s)
    2035 Post(s)
    Quote Originally Posted by Nelupoptile View Post
    Hiya thanks for getting back to me my car got a avz or azv engine code will it qualify or is it only certain engines codes that are been on a recall because the injectors failure .thank you
    No such engine as an AVZ so it must be an AZV and that was only fitted to the Golf 5, Jetta 5 and Touran so which car do you have?
  2. Re: Injector Failures - Possible recall
    Feb 2010
    Caithness
    05 Sport BKP 81,876 miles Injector failed.
    Got all 4 replaced and loom. Service impeccable and seeing mpg figures I've never seen before so a happy chappy.
    Convinced I wouldn't have had been aware of this possibility without this forum so a huge thank you guys!
  3. Re: Injector Failures - Possible recall
    Jul 2009
    crawley, west sussex
    mine went in there today with a failed injector, they said they have 3 passats with dead injectors!! my other half broke down on the M23 / A23 handcross hill on wednesday afternoon, stopped dead in the slow lane (2 lane section southbound) with our 2 year old in the car, police had to close the road to recover the car. Mega dangerous!! I have got to wait til monday for them to look at it, no questions from VW customer services or Crawley VW, they just said bring it in, we will check it then replace all injectors F.O.C. fingers crossed.
    Black '56 2.0 TDI 170 estate 86000miles
  4. Re: Injector Failures - Possible recall
    Dec 2010
    Chester Cheshire
    Picked car up today, car running like a dream. I was even told by the service manager to contact VW customer care and claim back the money I spent changing 2 injectors earlier in the year. He said I will get it back no problem. He also said they were doing cars that had zero service history on an FOC basis !!
  5. Re: Injector Failures - Possible recall
    Sep 2011
    London, UK
    Quote Originally Posted by Norfolk-Boy View Post
    RED reference your DSG issue are VW sorting it out?
    Well sort of, they wanted £1600 for it but i had an inspection done by AA before i bought the car, they picked up on this so i bought the car (from CarGiant) with the agreement that if VW find a fault CarGiant will fix it for free. Since did find the fault CarGiant are picking up the cost so handing the car in on Wednesday.
  6. Re: Injector Failures - Possible recall
    Mar 2010
    Knottingley, England
    Hi just got my '55 passat 2.0tdi (with new injectors recently fitted) back after having a major breakdown leading to 3 new valves/followers fitted + new cambelt kit etc. Engine is missing under acceleration/running lumpy and kicking loads of unburned diesel smoke out.be most grateful if anyone can run me through the procedure on how to set up injectors correctly please?
  7. Re: Injector Failures - Possible recall
    May 2008
    Okay, for anybody that has missed my separate thread.
    Car had new injectors/wiring loom on Tuesday of this week.The car hadn't suffered any previous problems. Yesterday morning the yellow engine warning light came on, car was running okay. Took it straight into Dealers. They have discovered that the wiring loom fitted was beginning to fail after a handful of miles.
    Have now got a second new wiring loom and seems okay.
    Somebody mentioned a few weeks back that they thought the injectors and wiring looms were being recycled after examination and reconditioning.
    What do you guys think, was I just unlucky or are they really doing that?
  8. Re: Injector Failures - Possible recall
    Feb 2007
    The VOSA agreement is for new parts.
    I can't see them taking such risks with a government body overseeing and taking a close interest in the whole repair operation which is currently underway..
  9. Re: Injector Failures - Possible recall
    135 Post(s)
    2035 Post(s)
    The injectors being supplied have an X at the end of the part number which means they are exchange and INFERS that they are reconditioned units but from looking at them they appear to be new although it is hard to tell.
    The set up procedure is to set the injector rocker arm at maximum lift preferably using a dial gauge but after doing this numerous times I can do it without now
    Then the adjuster nut is released and you use a 6-mm hex (Allen) key to wind the adjuster down until it hits a firm stop, then you back the adjuster off 180 degrees (I use an angle gauge so as to be extremely precise)
    and then tighten up the adjuster. Repeat this step for all the injectors.
    This is on an 8v but is the same procedure
  10. Re: Injector Failures - Possible recall
    Quote Originally Posted by Quatrelle View Post
    I'd be grateful if you let me know how you get on with the French bit, in view of my ongoing battle with VW France to get mine sorted out.
    Oui d'accord, pas probleme!
  1. Attention 2.0 tdi Injector failures - information
    By mm707 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-04-2011, 06:25 PM
  2. Audi 170 PS Injector Failures (A3s and A4s) - VOSA action
    By jfarhead in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-04-2011, 10:42 PM
  3. Question Injector failures - some info required please
    By mm707 in forum Chat - Anything with wheels
    Last Post: 26-03-2011, 08:38 PM
  4. Injector loom recall?
    By skartsocket in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-09-2009, 01:41 PM
  5. Seat Belt Recall Problems / Recall?
    By ChillOut in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-04-2007, 02:48 PM
