Thread: oil leak from turbo
Results 1 to 10 of 10
  1. oil leak from turbo
    Jul 2007
    I found out yesterday that I have an oil leak from turbo. How long before I need a new turbo and what will the cost be?
  2. Re: oil leak from turbo
    133 Post(s)
    1987 Post(s)
    They all do that, don’t worry about it until it starts going into limp mode. To have the blower pulled, rebuilt and refitted should cost you around £850 tops.
  3. Re: oil leak from turbo
    Jul 2007
    Is their anything I can do about leak in advance? or is it a case of wait and see to see if oil goes more and more?
  4. Re: oil leak from turbo
    133 Post(s)
    1987 Post(s)
    How many litres of oil are you putting in per 1000 miles?
  5. Re: oil leak from turbo
    133 Post(s)
    1987 Post(s)
    Shahid, clear your PM folders please, that way when you send a PM to people they can reply!
    Unless the floor looks like this after disconnecting the lower intercooler hose, you have nothing to worry about.
  6. Re: oil leak from turbo
    Jul 2007
    sorry Crasher re inbox!! should i disconnect the intercooler hose to see how much oil is leaking?
  7. Re: oil leak from turbo
    133 Post(s)
    1987 Post(s)
    Yes, have a look but how much oil is it using?
  8. Re: oil leak from turbo
    Jul 2007
    at moment use of oil seems normal to me
  9. Re: oil leak from turbo
    133 Post(s)
    1987 Post(s)
    Then I don’t think you have anything to worry about. I have seen two year old cars with less than 20k on them with oil dripping off the turbo and charge air cooler connections. Some comes from the turbo, some from the breather and unless you are using a noticeable amount of oil, there is nothing to worry about.
  10. Re: oil leak from turbo
    Jul 2007
    Thanks Crasher I really appreciate your advice and for taking time out to reply.
  1. Oil Leak.....Maybe Turbo Oil Line
    By Clinterous in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-06-2011, 07:46 PM
  2. suspect turbo oil leak
    By 123markG in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-03-2009, 08:31 PM
  3. turbo oil leak. or could it be something else??
    By gemmell88 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-04-2008, 04:18 PM
  4. Turbo oil leak
    By Buzzlb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-04-2008, 12:06 PM
  5. 2.5 Tdi V6 Turbo Oil Leak
    By wadi110 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-03-2008, 08:46 PM
