Thread: Rev counter, high oil pressure switch not working
Results 1 to 10 of 10
  1. Rev counter, high oil pressure switch not working
    Jun 2011
    Northampton
    Hi i have a 1993 2.0 16v coupe and the rev counter is not working and the oil light comes on if the car is reved or when the cars cold and the pressure is high. I have looked at the earths and the alternator wires and it all looks ok so I'm assuming that the 2 problems are unrelated, I can get a new pressure switch but don't know where to start with the rev counter. Would appreciate any ideas.
    Cheers stu
  2. Re: Rev counter, high oil pressure switch not working
    Oct 2010
    reigate, surrey, uk
    sorry dont have any answers for you but i am sure i have read a few other threads on this topic so maybe a search on this may help you.
  3. Re: Rev counter, high oil pressure switch not working
    Jun 2011
    Northampton
    Cheers, iv had a look and it's effectively the rev counter is a pulse meter, I'm not to hot on electrics so looks like I'm going to get it looked at. I will fit a new oil pressure switch myself.
    Cheers for the reply
    Stu
  4. Re: Rev counter, high oil pressure switch not working
    Gwent
    Reading some of the similar threads, I would get the alternator checked out?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  5. Re: Rev counter, high oil pressure switch not working
    Jun 2011
    Northampton
    I had a look at the the wireing as it's pretty minimal and it all looks ok and all the connections seem ok, or do I need an auto electrician to have a look at it plus the oil pressure light is only on when the engine is cold or when revved so it's got to be the high pressure switch, if it was the alternator wouldn't the light be on all the time or intermittently, not just when the pressure is high?
    Cheers stu
  6. Re: Rev counter, high oil pressure switch not working
    Gwent
    See the 'similar threads' listed at the bottom of your post, oil pressure alarms and rev counter failure seems to go hand in hand with alternator gremlins.
    I'm not sure whether the high oil pressure switch should be 'made' or open, you could simulate either by shorting or disconnecting the wire. Chances are there will be no change, because the fault lies elsewhere.
    As I understand it, the batt light will come on only if the voltage is low - i.e the alternator is not charging. This fault seems to related to the small wires from the altrnator or something internal. One of the other threads found a cure was to fit a valeo alternator in place of a Bosch one.
  7. Re: Rev counter, high oil pressure switch not working
    Jun 2011
    Northampton
    Fixed the problem. I cleaned up all the terminals then sprayed the whole alternator with wd40.
    Stu
  8. Re: Rev counter, high oil pressure switch not working
    Gwent
    Pleased you fixed it, nice to know it probably was the alternator.
  9. Re: Rev counter, high oil pressure switch not working
    Jun 2011
    Northampton
    Just need a power steering pump now and the car will be back on the road. It's amazing what goes wrong when a car has been parked up and left for 5 years, have already fixed the rear lights that corroded and fitted a cv boot. On e the power steering pump is done I will be taking her for an mot.
    Stu
  10. Re: Rev counter, high oil pressure switch not working
    Gwent
    Good luck with the test
  1. Please Help Oil Pressure warning/Rev counter issue
    By Sailorf80 in forum The Commercial Range
    Last Post: 12-08-2011, 03:33 PM
  2. T4 rev counter and oil pressure warning light
    By nofear in forum The Commercial Range
    Last Post: 18-10-2008, 11:05 PM
  3. T4 oil pressure light and rev counter
    By nofear in forum The Classic VW's
    Last Post: 20-07-2008, 02:44 PM
  4. A6 Avant 2.4 Warning lights for: ABS + Oil Pressure + No rev counter
    By kevnewcastle in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-03-2008, 07:54 PM
  5. my oil pressure light flashes and rev counter has stoped working
    By DUBTUB in forum Golf MK3 - 1993 - 1999
    Last Post: 21-10-2007, 07:26 AM
