Thread: Noise when turning left
  1. Question Noise when turning left
    Jan 2009
    Birmingham
    36 Post(s)
    Ok people any help I've got a audi a4 1.9 tdi 115 sport 2004 when driving and taking long left bend getting a wheel bearing like noise grinding turning right it's fine just wondering what side it could in the car I feels like drivers side rear bearing also my rear arb bushes are split it been a out two years know since I had them diagnosed could it be the rear arb making the noise and how hard is the rear bearing to replace getting the bearing noise also at motorway speeds too
  2. Re: Noise when turning left
    Jun 2011
    West Yorkshire
    sounds like bearing, my previous audi went at 110k, mind you this was a turbo quattro sport. bearing came back @ aprox £20 each or so and took 45 mins to do each side, as if 1 side had gone, the other is not far behind. if you take a left, you load the left side with thrust, this puts stress on the bearing and allows the right side to be less loaded. The roll bar bushes wont cause a grind, they would cause a knock...
  3. Re: Noise when turning left
    Jan 2009
    Birmingham
    36 Post(s)
    Quote Originally Posted by Hudds Chip Tune View Post
    so best to change both rear bearing then
  4. Re: Noise when turning left
    Jun 2011
    West Yorkshire
    how much mileage has you car done? the time it takes to do 1 side, and if you are going to keep the vehicle, might as well do the other.. make sense.
  5. Re: Noise when turning left
    Jan 2009
    Birmingham
    36 Post(s)
    It's done 129000
  6. Re: Noise when turning left
    Jun 2011
    West Yorkshire
    yep, go for both rear, its about the mileage when they start to rumbble..
  7. Re: Noise when turning left
    southampton
    I have similar symptoms, I have a slight scuffing sound from both sides when turning each way ????? I am not sure if it is wheel bearings or brake discs scuffing had new pads and discs (Audi dealer ) , had not deteriorated much in the last 3 months??? doesn't sound like a wheel bearing whine ,but it is a scuffing type sound.
    any ideas ??
    regards Trevor.
  1. Noise when turning left
    By SMEG in forum Golf MK5 - 2004 - 2009
    Last Post: 20-03-2011, 05:06 PM
  2. Engine Noise Louder when turning left - Sharan 2000/X 1.9TDi 110
    By dmjbill in forum Touran - Sharan - Caravelle
    Last Post: 08-09-2009, 09:51 AM
  3. Please Help knocking from n.s.f. when turning left golf 1.6s.e
    By c10 tsh in forum Golf MK4 - 1999 - 2004
    Last Post: 01-08-2009, 02:29 PM
  4. Rubbing, grinding noise when turning left
    By trousdala in forum Golf MK4 - 1999 - 2004
    Last Post: 18-05-2008, 09:24 PM
  5. Knocking when turning left.
    By forresttc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-05-2007, 12:34 PM
