Thread: golf mk4 loss of power... help please
Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. Re: golf mk4 loss of power... help please
    #21
    Jun 2007
    thanks for the reply but i have a feeling it is something more along the lines of a leak. but definatly a good point, we cant asume that just because its new its ok
  2. Re: golf mk4 loss of power... help please
    #22
    Jun 2007
    had a diagnostic. i havent got it here but vag com stated over boost im sure the number was 17695. the garage said that it sounded like the vanes were sticking so i really dont know what to do. what could cause an over boost.
    it will cost me 250 to let them get the turbo off and put it back if i need a new one, i have to do this anyway as you cant see the garret number on it if i have to order a turbo.
    i must admit it is a strange noise it makes under load. im stuck as i cant sell the car in the state its in as who ever comes to buy will hear the noise and wont want it.
  3. Re: golf mk4 loss of power... help please
    #23
    Jun 2007
    ill have to double check that number thoas that is off the top of my head but it stated over boost and said it was intermittent.
    the garage that did the test said they thought they would have to look at the turbo as they thought the turbo was the likely cause and that the vanes might be sticking due to crabon build up. does that sound likely. id really appreciate some advice as its really beginning to get me down and im struggling with money as it is. i really dont want to commit to something if it isnt necessary
  4. Re: golf mk4 loss of power... help please
    #24
    Sep 2007
    Quote Originally Posted by tannerzxr View Post
    you will of heard it before as i have read on here before but i just need someone with experience to back my decision or oppose it. its a gt tdi 150 , iv had the turbo cut out then be ok once i re start the car so i thought it must be electronic as the tubo obviously hadnt seized. it also feels a little sluggish.
    i took it to vw garage near mine and they put it on the diagnostic and said nothing showed up. surely even if my car had had the turbo cut out just once it should have been recorded on the ecu history. they said there was nothing.
    i noticed them maf sensors are notorious so i think ill chance it and see if my car benefits is there anything else i can do. what benefit does disconnecting the battery for 20 mins have.
    id really appreciate it if some one could offer me som help or suggestions.
    could be ECU or fuel starvation
  5. Re: golf mk4 loss of power... help please
    #25
    Jun 2007
    has any one got any experience of this my turbo doesnt sound right and a sticking van sounds likely, but would that be because of an over boost. thanks for the reply.
    ive got my car to book in for having turbo taken off and checked. bl00dy car
    any suggestions welcome.
  6. Re: golf mk4 loss of power... help please
    #26
    Aug 2007
    Northern Ireland
    Well until you can confirm the fault code it's gonna be difficult!
    http://wiki.ross-tech.com/index.php/...ry:Fault_Codes
  7. Re: golf mk4 loss of power... help please
    #27
    Jun 2007
    good point lol. ill have to search for the report sheets.
  8. Re: golf mk4 loss of power... help please
    #28
    Sep 2007
    Ive got the exact same problem with my car.
    Girlfriends brother is mechanic down at local VW dealer so he took it in and whipped it onto the diagnostics machine ( not sure which one but it was the main VW dealer in Carlisle (not some backstreet Harry)) and it came up with overboost aswell.
    He told me he could take the turbo to bits and lubricate the vanes as a temporary measure but apart from that it had to be a new turbo!!
    I'll be interested to hear what the problem actually is when you find out!
  9. Re: golf mk4 loss of power... help please
    #29
    Jun 2007
    this is exactly how the vag com print off reads
    1 fault found:
    17965 - Charge Pressure Control : positive deviation
    P1557 - 35-10 - - - Intermittent
    Readiness: 0 0 X X X
    hope that makes any sense. id really appreciate some experience of this fault if possible.
    some thing hisses or does not sound right tho if that makes any sense
  10. Re: golf mk4 loss of power... help please
    #30
    Aug 2007
    Northern Ireland
    17965/P1557/005463 - Charge Pressure Control: Positive Deviation
    Possible Symptoms
    Reduced power output
    Limp mode
    Possible Causes
    Boost Pressure too High
    Hoses/Pipes incorrect connected, disconnected, blocked or leaking
    Charger Pressure Control defective
    VNT (variable nozzle turbo): nozzles stuck
    Solenoid Valve for Boost Pressure Control (N75) defective
    Possible Solutions
    Check Hoses/Pipes to/between Components
    Check Solenoid Valve for Boost Pressure Control (N75)
    Check / Clean / Replace Charge Pressure Control
    Check / Clean mechanism for variable nozzles
  1. loss of power
    By sacko17 in forum Touran - Sharan - Caravelle
    Last Post: 13-11-2007, 01:54 PM
  2. Golf TDI Mk3 loss of power
    By Mark Scruby in forum New Member Introductions
    Last Post: 31-08-2007, 10:11 AM
  3. golf 4 gt tdi power loss help, (PLEASE'S)
    By golf4TERRY in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-07-2007, 06:07 PM
  4. Golf TDI Power Loss
    By donnytella in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-07-2007, 10:31 AM
  5. Sick Golf GT 150 Pd TDi. Power loss, poor idle
    By lchris21 in forum Archive posts
    Last Post: 17-12-2006, 09:02 PM
