Thread: golf mk4 loss of power... help please
Results 1 to 10 of 30
  1. Re: golf mk4 loss of power... help please
    Jun 2007
    good point lol. ill have to search for the report sheets.
  2. Re: golf mk4 loss of power... help please
    Sep 2007
    Ive got the exact same problem with my car.
    Girlfriends brother is mechanic down at local VW dealer so he took it in and whipped it onto the diagnostics machine ( not sure which one but it was the main VW dealer in Carlisle (not some backstreet Harry)) and it came up with overboost aswell.
    He told me he could take the turbo to bits and lubricate the vanes as a temporary measure but apart from that it had to be a new turbo!!
    I'll be interested to hear what the problem actually is when you find out!
  3. Re: golf mk4 loss of power... help please
    Jun 2007
    this is exactly how the vag com print off reads
    1 fault found:
    17965 - Charge Pressure Control : positive deviation
    P1557 - 35-10 - - - Intermittent
    Readiness: 0 0 X X X
    hope that makes any sense. id really appreciate some experience of this fault if possible.
    some thing hisses or does not sound right tho if that makes any sense
  4. Re: golf mk4 loss of power... help please
    Aug 2007
    Northern Ireland
    17965/P1557/005463 - Charge Pressure Control: Positive Deviation
    Possible Symptoms
    Reduced power output
    Limp mode
    Possible Causes
    Boost Pressure too High
    Hoses/Pipes incorrect connected, disconnected, blocked or leaking
    Charger Pressure Control defective
    VNT (variable nozzle turbo): nozzles stuck
    Solenoid Valve for Boost Pressure Control (N75) defective
    Possible Solutions
    Check Hoses/Pipes to/between Components
    Check Solenoid Valve for Boost Pressure Control (N75)
    Check / Clean / Replace Charge Pressure Control
    Check / Clean mechanism for variable nozzles
  1. loss of power
    By sacko17 in forum Touran - Sharan - Caravelle
    Last Post: 13-11-2007, 01:54 PM
  2. Golf TDI Mk3 loss of power
    By Mark Scruby in forum New Member Introductions
    Last Post: 31-08-2007, 10:11 AM
  3. golf 4 gt tdi power loss help, (PLEASE'S)
    By golf4TERRY in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-07-2007, 06:07 PM
  4. Golf TDI Power Loss
    By donnytella in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-07-2007, 10:31 AM
  5. Sick Golf GT 150 Pd TDi. Power loss, poor idle
    By lchris21 in forum Archive posts
    Last Post: 17-12-2006, 09:02 PM
