Thread: Won't start,,,
  1. Wink Won't start,,,
    Jun 2011
    Loughborough, Leics
    A4 quattro, 1.9tdi 110bhp. 130k miles.
    I've just changed the fuel filter, fitted OEM Audi replacement.
    Took old one off, primed new one with fuel, connected it up,,, started car and it ran briefly, switched off, got cleaned up then tried to start it again but it will not have it.
    Just turns over but no life.
    Please, does anyone have any suggestions of what I may have done wrong, or may not have done.
    Many thanks in anticipation.
    ,,,peejayay,,,
    Bonny Scotland
    It'll be air in the system. Even priming the new filter doesn't guarantee there won't be an air bubble.
    Try cracking off the high pressure pipes at the injectors one at a time while you crank the engine till there is clean fuel flow.
    Alternatively tow the car in 2nd gear with another vehicle until it fires.
    Frank
  3. Re: Won't start,,,
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Cycle the ignition `ON` and `OFF`, leaving a moment before turning it off to let the pump in the tank purge the air out the system. Do this a number of times. Then crank engine. It should go after this.
    Alan.
    VW T6 150 DSG Camper £££
  1. Please Help tdi hard to start, now no start
    By rjd1284 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-02-2011, 10:16 AM
  2. Won't start: faulty start valve?
    By Shaka1976 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-07-2010, 04:22 PM
  3. Question Shall we start.....
    By kite in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-08-2009, 05:36 PM
  4. Please Help A4 won't start please help!!
    By tomyj81 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-04-2009, 04:23 PM
  5. Just saying Hi before I start
    By DubDick in forum New Member Introductions
    Last Post: 03-09-2007, 06:39 PM
