Thread: Boot Lid
  1. Boot Lid
    Mar 2008
    Anyone know where the best place is to get A4 Saloon boot lid? Don't mind if its second hand or different colour as long as its in London somewhere?
    I've tried a few breakers and they don't have any stocked.
    Anyone got or know of spares?
    The is all to do with the problem I had with my boot lock not releasing, even when trying to operate it manually from behind the panels.
    Only solution the garage suggested is to cut around the lock which means i need a whole new boot
    thanks
  2. Re: Boot Lid
    Feb 2010
    Sudbury
    Seems a bit drastic! Have a word with a local locksmith he might be able to drill out the old one's barrel then get a new barrel for it. worth a phone call. There again try another garage with someone that Knows, or if you're in the AA or RAC or similar why don't you hand the problem over to them.
  3. Re: Boot Lid
    Aug 2010
    stone uk
    There's got to be an easier way than cutting the actual boot open!!! If you've got the panels off you must be able to unscrew the latch ?!?!?
  4. Re: Boot Lid
    Mar 2008
    Finally got it open.
    si69jc - Unfortuantely I couldnt even get inside to take any panels off as I have a saloon and no drop down seats. Had to work from the outside only. but eventually had to unscrew the latch but still wasnt easy to get to
    I called AA to give it a try and after an hour of work he finally got it open.
    It wasnt straight forward though and he said its the first that he's seen it so jammed up.
    I previously took it to a garage to cut a flap behind the number plate to get to the lever so AA had to use that to get access to the mechanisim.
    Pulling the lever manually still didnt open the boot.
    Eventually had to remove the clips/lever and all the screws so that he could get to the lock at the bottom.
    Turns out part of the plastic locks/clips had broken off and got wedged so couldnt release the latch.
  1. Please Help Boot Lid Problem
    By The Technician in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-03-2012, 11:07 PM
  2. Question B7 Boot Lid
    By Macdoon in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-03-2011, 08:25 PM
  3. auto boot lid
    By mayersy in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-12-2010, 04:32 PM
  4. boot lid fault
    By lukev6tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-05-2009, 06:01 PM
  5. Electrical problems with boot lid and Roof container lid
    By cabri-ole in forum Audi A4 - Archive Topics
    Last Post: 14-02-2007, 07:51 PM
