Thread: stiff pasenger doors!! grease no help.
  1. stiff pasenger doors!! grease no help.
    Jun 2011
    SHEFFIELD
    new to the forum and my first post, although i have found many threads helpful. the doors on my 2000 a4 passenger sides are very stiff and i also have a squeak on the drivers side door, have tried white grease but still has not worked. you cant actually shut the passenger doors without pushing them!! any suggestions welcome, thanks, maza
  2. Re: stiff pasenger doors!! grease no help.
    Dec 2009
    southampton uk
    Have you had the car long?If not are the hinges rusted or neglected?I would get some penetrating oil in them to free the hinges assuming that there is no damage which has caused the problems.If the door has be badly rehung this may cause the stiffness
  3. Re: stiff pasenger doors!! grease no help.
    Mar 2010
    Lyneham
    I have the same problem with my 2000 A4 Avant and would like to know how to fix this.
  4. Re: stiff pasenger doors!! grease no help.
    Jul 2009
    liskeard cornwall
    as mickeybutch suggested you need to spray penetrating oil into the hinges an a daily basis for a week so the oil can work in to the pins and to start to wash the corrosion out, patience is key and then get a good aerosole lubrication oil and spray well, remember that after each spray to work the doors as this will move the corrosion out of the pins
  1. Please Help Mk2 4 door - need driver and pasenger doors
    By Unbreakable in forum Golf MK2 - 1984 - 1992
    Last Post: 21-06-2010, 10:44 AM
  2. Golf Mk3 GTI Lambo/Scissor/Vertical Doors Doors
    By haider786 in forum Chat - Anything with wheels
    Last Post: 29-09-2008, 11:28 AM
  3. Grease pit
    By Lawler in forum Golf MK3 - 1993 - 1999
    Last Post: 17-08-2008, 03:26 PM
  4. Water in the rear pasenger footwell?
    By MacG130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-03-2008, 08:54 PM
  5. passat 2002 tdi front pasenger seat sqweaks when justed high only
    By FAROOQS in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-01-2008, 10:08 PM
