Thread: HELP HELP HELP - Glowplug Wiring Harness?????
  1. HELP HELP HELP - Glowplug Wiring Harness?????
    Warrenmole Guest
    Not having much luck....having had the emmisions warning light on with glowplug 3 error..I had the garage change the 4 glowplugs and reset the light, now 2 days go past and the light is back on, took it back and still says the same thing even though they were replaced...garage say it's probably the wiring harness...any ideas how much this will be...don't want to throw anymore money down the pan only for it to be something else..
  2. Re: HELP HELP HELP - Glowplug Wiring Harness?????
    Feb 2009
    Leicester, UK.
    A bit more information would help...
    What engine etc?
    What glowplugs have they fitted?
    And any garage that says 'probably' in any of their recommendations 'probably' doesn't know what their on about.
    MY07 B6 Passat 140 SE TDI
  3. Re: HELP HELP HELP - Glowplug Wiring Harness?????
    Norfolk
    It is quite common for garages to fit the wrong glowplugs which then damages the glowplug controller. What fault code have you got.
  4. Re: HELP HELP HELP - Glowplug Wiring Harness?????
    Warrenmole Guest
    sorry for the delay. ok the fault code is 17057, the garage assure me they fitted the correct glowplugs so don't know what to do now.???
  5. Re: HELP HELP HELP - Glowplug Wiring Harness?????
    Norfolk
    17057
    P0673
    Glow Plug/Heater Cylinder 3 (Q12) circuit, electrical Fault in Circuit
    I would want to check the exact make of glow plug. Garages often fit the wrong ones. Other than that, there must be a fault in the wiring.
  6. Re: HELP HELP HELP - Glowplug Wiring Harness?????
    Warrenmole Guest
    thanks, if it is the wiring where would i get it and how much would it roughly be???
  1. How to disconnect door wiring harness?
    By SebRogers in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-03-2011, 09:55 PM
  2. Injector Wiring harness replacement - How to??
    By macarthur.2000 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-10-2009, 11:31 AM
  3. Dash panel wiring harness
    By wmccann in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-05-2009, 10:38 AM
  4. Question Injector Wiring loom/harness help
    By gurvirb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-03-2009, 09:27 PM
  5. stereo wiring harness
    By otis_b in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-09-2007, 02:20 PM
