Thread: Passat Plenum Chamber Drain Holes
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
  1. Passat Plenum Chamber Drain Holes
    Apr 2009
    Wiltshire, United Kingdom
    I realise that there are masses of posts on this site regarding water ingress in the Passat, and I have had my own bitter experience of this in my own car - a 2005 Passat Highline Estate with 130 bhp TDI engine.
    After the recent heavy rain, I decided to check the plenum chamber on my car. After removing the plenum plastic cover, I found the area below the battery clear of water, but the space below the brake servo (on the driver's side of the chamber) had some water trapped in it. I sucked this water out with a length of plastic tubing connected to an old washing up liquid. I then tried to find the drain hole which might be blocked and causing the water to collect, but was unable to see the hole.
    Can any member please tell me precisely where I ought to find this drain hole so that I can clear it. Many thanks.
  2. Re: Passat Plenum Chamber Drain Holes
    135 Post(s)
    2043 Post(s)
    One hole I under the servo, you can’t see it but you can feel it with the battery out. The other is under the battery tray. DO NOT poke the drain bungs out, they are one way valves and are there to stop nasty fumes being drawn into the heater from under the car.
  3. Re: Passat Plenum Chamber Drain Holes
    Oct 2006
    I bow to Crashers superior knowledge on all things VW but I took my bungs out and have no smell in the cabin.
    I poked out the bung under the brake servo from beneath with a lonnnnng screwdriver.
    No water problems either!!
  4. Re: Passat Plenum Chamber Drain Holes
    Apr 2009
    Many thanks for above responses to my query. Is it possible to access/clear the blocked bung/drain hole under the brake servo without removing the battery, perhaps using a stiff piece of wire shaped to fit around the body of the brake servo unit? (I am rather pressed for time....)
  5. Re: Passat Plenum Chamber Drain Holes
    135 Post(s)
    2043 Post(s)
    You can do the one under the battery from below but the one under the servo needs the battery out.
  6. Re: Passat Plenum Chamber Drain Holes
    Apr 2009
    Quote Originally Posted by knoxman View Post
    We all are, and that's exactly why they should be removed
    Regards
    Jim
  7. Re: Passat Plenum Chamber Drain Holes
    135 Post(s)
    2043 Post(s)
    I say poke them clean, don’t remove them.
  8. Re: Passat Plenum Chamber Drain Holes
    They are specifically designed duck bill water vents and should not be removed. They should be cleaned flushed and sterilised, dettol or the like. A hot engine gives off fumes and the bungs is designed to stop that air from entering the plenum chamber and your head. In traffic queued up the exhaust fumes are blown under your car and rise up to the plenum chamber. With the bungs operational you are only breather the air from just in front of the windscreen. Regards Peter
  9. Re: Passat Plenum Chamber Drain Holes
    Apr 2009
    Quote Originally Posted by Peter D View Post
    Throw them away
    The bungs would have to be blocked to be fume-proof, and we all know what that means... 1 shower of
    rain or 1 car wash and you run the risk of serious damage. Its a flawed theory, and design!
    The mass of air-pressure that sits on the plastic grills, on top of the plenum chamber, far exceeds any
    pressure trying to rise into the bung-holes from underneath, and this increases with speed because
    of air-flow. They ******-up with these things, big-time.
    Regards
    Jim
  10. Re: Passat Plenum Chamber Drain Holes
    135 Post(s)
    2043 Post(s)
    Thank God, at last someone agrees with me!
  1. At last! A uk recall for the passat brake failure water leaks plenum chamber
    By snapdragon in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2016, 11:27 AM
  2. Plenum Chamber Drain Holes
    By manclad in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-10-2010, 08:47 PM
  3. oil fumes , plenum chamber drain valves
    By billy g in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-10-2009, 12:49 PM
  4. plenum chamber drain valves
    Last Post: 16-10-2009, 03:06 PM
  5. Passat Plenum Chamber
    By bricam1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-10-2008, 05:32 PM
