Thread: Cant Reprogramme Key
Results 1 to 8 of 8
  1. Cant Reprogramme Key
    Jun 2011
    Ireland
    Hey guys I recently bought a 2001 B6 A4 and neither of the keys work, I've tried reprogramming them useing the methods posted on here but nothing seems to work
    Any Ideas?
    Thanks in advance
  2. Re: Cant Reprogramme Key
    Apr 2009
    If your sure the batteries are ok, try this ; http://www.youtube.com/watch?v=83Co22N70Gw
    Regards
    Jim
  3. Re: Cant Reprogramme Key
    Jun 2011
    Ireland
    Yeah thats the method i've been useing, but with no luck!
    Changed both batteries today aswell just to be sure.
    All the guides i've read seem to be for programming one key with the other already working, wheras neither of mine work!
    Could this be the problem?
  4. Re: Cant Reprogramme Key
    Apr 2009
    Quote Originally Posted by s-mac View Post
    Not really, you only need a blade in the ignition to program one remote.
    Could the ccm be flooded?
    Regards
    Jim
  5. Re: Cant Reprogramme Key
    Jun 2011
    Ireland
    Whats the ccm?
    Thanks for the help so far by the way
    Edit: Central conconvience controller right?
    Is there a way of unflooding it?
  6. Re: Cant Reprogramme Key
    133 Post(s)
    1986 Post(s)
    You may need to resort to VCDS for this
    Channel 021: Remote Control Matching
    [Select]
    [46 - Central Convenience]
    [Adaptation - 10]
    Channel 021.
    [Read]
    • Choose the memory position you want the new key be matched on by entering it's number (e.g. "3" for memory position 3). Make sure to TYPE IN the number instead of scrolling up to it, otherwise you will not be able to click [Test].
    [Test]
    • Now press any button on the remote you want to match.
    • The meas. block field above will change from Not Recogn. to Recognized.
    [Save]
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    Notes: You can check the current memory positions using Meas. Block 007.
  7. Re: Cant Reprogramme Key
    Jun 2011
    Ireland
    Thanks, can this be done with the version of vagcom that can be downloaded from rosstech
  8. Re: Cant Reprogramme Key
    133 Post(s)
    1986 Post(s)
    Yes, as long as it is registered.
  1. Had my key stolen, help needed urgently - panic over, key found - Phew
    By Mega Maniac in forum Chat - Anything with wheels
    Last Post: 03-07-2009, 07:56 PM
  2. Question Reprogramme key
    By pukeyelloww in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-06-2009, 04:10 PM
  3. Erased key code with vag.no key cent lockin.HELP!
    By giggsy07 in forum VCDS - General Questions
    Last Post: 23-04-2009, 06:38 PM
  4. car beeps just like key in ignition - but no key in igntion
    By integra93_4 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-02-2009, 11:26 AM
  5. How to reprogramme Allroad key
    By Giraffe in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-05-2008, 11:28 PM
