Thread: J519 onboard supply audi a4 where is this located?
Results 1 to 10 of 15
  1. J519 onboard supply audi a4 where is this located?
    Jun 2011
    United Kingdom Bedfordshire
    hi just wanted to know.where is the j519 power supply located in a 2003 audi a4 cabriolet. Iv been having issues (posted another thread) and doing some research seems like this is the cause so want to know where it is located exactlyand can go on form there. THANK YOU..
  2. Re: J519 onboard supply audi a4 where is this located?
    Jun 2011
    it may also be called connivence module?
  3. Re: J519 onboard supply audi a4 where is this located?
    135 Post(s)
    2042 Post(s)
    The “onboard supply control unit”, it is located under the facia below the relay plate and is mounted horizontally. You have to take the drivers side lower dash storage compartment out to access it.
  4. Re: J519 onboard supply audi a4 where is this located?
    Jun 2011
    So under the steering wheel i have to take all the plastic off and its in there? thanks
  5. Re: J519 onboard supply audi a4 where is this located?
    Jun 2011
    and also if i disconnect my cluster will i be able to connect it back up without having to reprogram anything. thanks. Am i looking in the right place? thanks
  6. Re: J519 onboard supply audi a4 where is this located?
    Jun 2011
    Found it. Basically my hazards flash for 4 mins. If i discconnect the wire connected to the module which controls all the outside lights ie signals brake lights etc then the hazards go off but also all the other lights.If i got a new one of these would this solve my problem. Anything would help. thanks
  7. Re: J519 onboard supply audi a4 where is this located?
    135 Post(s)
    2042 Post(s)
    Your hazards flashing for 4 minutes suggests the alarm is going off and the siren is faulty, a common issue. You can’t just plug and play with new units; they have to be coded in.
  8. Re: J519 onboard supply audi a4 where is this located?
    Jun 2011
    siren is faulty? how would i check this? and how would i go about fixing this issue? thanks your help is much much appreciated. thank you. Im really stressing out just want the car fixed. thanks
  9. Re: J519 onboard supply audi a4 where is this located?
    Jun 2011
    i did have the car scanned and the fault came up as 00474 control module for immobilizer no commucation? if that helps. thanks
  10. Re: J519 onboard supply audi a4 where is this located?
    135 Post(s)
    2042 Post(s)
    You need a fault code reading system such as VCDS to be able to fix this yourself.
  1. J519 Power Control Unit
    By t11tmm in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-12-2013, 09:21 AM
  2. Where is the boot power supply located
    By pgarner in forum Bora - 1998 - 2005
    Last Post: 17-09-2010, 01:52 PM
  3. 04 plate t5 onboard power supply
    By MARK68 in forum The Commercial Range
    Last Post: 13-08-2010, 03:53 PM
  4. Audi A6 ESP Fault 0214 Supply Volage
    By trebor69 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 28-02-2009, 12:06 PM
  5. Component: J519
    By bez101 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-10-2008, 10:37 AM
