Thread: VCDS help
  1. Post VCDS help
    Mar 2007
    nr Gloucester
    Hope someone can help. Need advice on using VCDS.
    A little background...
    I have owned the my 2006 2.0 tdi 170 A4 for nearly 2 years. Ever since i have had it it has run quite badly from cold on idle. 3 months after owning, first injector went. Then nothing until about 4000 miles ago when the glow plug light came on and the car konked out. To my amazement car started and that was 4000 mile ago. Took it to a garage at the time who scanned it (I didn't get the codes) but they said it was to do with injector one - short to plus. Since then the car has run but really rough on idle (much worse than before) when cold and hesitates around 1800rpm.
    I am adamant that the reason for the rough idle is to with the injectors. I have just bought a copy of VCDS and want to know if there is a way of checking what fueling is going into each injector?
    Hopefully someone out there can help.
    Thanks in advance.
    Ad
    Audi A6 (C7) 3.0 BiTDi Black Edition 2016
  2. Re: VCDS help
    Norfolk
    Block 013 can be logged at idle or any engine speed. It doesn’t have to be an acceleration log.
    013. 1 Injection Quantity, Deviation Cyl. 1
    013. 2 Injection Quantity, Deviation Cyl. 2
    013. 3 Injection Quantity, Deviation Cyl. 3
    013. 4 Injection Quantity, Deviation Cyl. 4
    A graph of these results can be done against the time stamp column but it will look a mess.
    It is simpler to average the results for each injector and look for any really odd figures.
    All 4 injectors should have similar figures as close to zero as possible.
    E.g.
    13, 1, Injection Quantity, Deviation Cyl. 1. -0.28 mg/str
    13, 2, Injection Quantity, Deviation Cyl. 2. -0.49 mg/str
    13, 3, Injection Quantity, Deviation Cyl. 3. 0.56 mg/str
    13, 4, Injection Quantity, Deviation Cyl. 4. 0.21 mg/str
    If one injector is well out of specification compared to the others it could be faulty or it could be a faulty cam lobe.
    If all figures are all over the place it suggests worn camshafts.
    It is hard to tell if an injector oddity is due to an injector fault or a camshaft fault.
    Apparent multiple injector faults are usually worn camshafts.
  3. Re: VCDS help
    Mar 2007
    nr Gloucester
    Thanks for that,
    had a bit of a play this afty and found the following-
    At Idle
    18:03:10 Group 013
    -0.41 mg/str Inj. Quantity
    0.49 mg/str Inj. Quantity
    -1.00 mg/str Inj. Quantity
    0.93 mg/str Inj. Quantity
    At around 1300 rpm
    18:05:03 Group 013
    -0.85 mg/str Inj. Quantity
    -0.36 mg/str Inj. Quantity
    -0.79 mg/str Inj. Quantity
    2.01 mg/str Inj. Quantity
    Engine is quite lumpy at idle, when at 1500 rpm its shake you teeth out!
    As i mentioned before, there was a fault with injector 1 but injector 4 has been replaced already. Does that suggest the rest toast?!!
    Ad
  4. Re: VCDS help
    Mar 2007
    nr Gloucester
    Have now posted this on B7 forum
    https://www.vwaudiforum.co.uk/forum/s...946#post649946
    Ad
  5. Re: VCDS help
    Norfolk
    Your figures are within VW spec. These injectors suffer faulty electronics but usually they play up for a little time and then the ecu switches off. Then the car won't start.
    Have a look at the fuel filter to check it isn't full of oil. (black). One thing that can cause your symptoms is damaged seals on the injectors. These can be damaged when an injector is fitted.
  6. Re: VCDS help
    Mar 2007
    nr Gloucester
    Thanks Martin
    Its had the injector seals done twice to no avail unfortunately. I've got to do a full service soon, so i'll check the filter for oil then.
  1. advice on buying VCDS/VCDS-lite
    By borakev in forum VCDS - General Questions
    Last Post: 16-04-2019, 05:20 PM
  2. help please in need of vcds
    By ants a4 in forum VCDS - Users Locations
    Last Post: 25-02-2011, 07:22 PM
  3. vcds
    By bikesken450 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-02-2011, 10:39 PM
  4. Have VCDS - what can I do with it?
    By allanmb in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-02-2011, 01:13 AM
  5. vcds help
    By dilun in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-10-2010, 01:14 PM
