Thread: A4 2011 SE - headlamp conversion for continental driving
  1. A4 2011 SE - headlamp conversion for continental driving
    Jul 2011
    Peterborough UK
    Never seen so many instructions in the leaflet with the converters....I am presuming as we have standard headlamps that they are halogen & standard (i.e. not projector style or xenon).
    Has anyone actually managed to fit these stickies - we have used them on lots of previous cars but always seemed to have ridged lampglass to help us - clear glass is a bit alarming and not sure of getting it right first time.
    Any advice please!
  2. Re: A4 2011 SE - headlamp conversion for continental driving
    May 2007
    knee deep in clunge
    14 Post(s)
    There are correct easy fit audi stickers for around £60 as the after market stickers are rubbish.I drive to France twice a year and normally the only night driving I do is from the ferry or to the ferry, I have the after market stickers in the car but I just adjust the headlight aim lower to prevent glare for oncoming drivers.
    I only used the stickers once and found it near impossible to see as there are few street lamps and its mostly pitch dark
    .Attachment 14357Attachment 14358
    Headlight (driver's side): –
    Remove protective backing from masking foil.
    Apply the masking foil flush around the edge -2- of the headlight lens.
    Adhere the masking foil on the headlight lens, as shown in illustration. – Separate marking foil -1- from masking foil -3- at perforation -arrow- and then remove again from headlight lens.
    Headlight (passenger's side): –
    Adhere the masking foil on the headlight lens, as shown in illustration. – Separate marking foil -3- from masking foil -1- at perforation -arrow- and then remove again from headlight lens.
  3. Re: A4 2011 SE - headlamp conversion for continental driving
    Jul 2011
    Peterborough UK
    We've driven hundreds of miles in France before with the standard stickers with no problems.....but I really am not going to shell out £60 for audi ones! I presume the ones you have illustrated are the audi ones as they don't bear any relation to the AA-approved ones I have (which look like a comet)?
  4. Re: A4 2011 SE - headlamp conversion for continental driving
    May 2007
    knee deep in clunge
    14 Post(s)
    use the pictures as a guide for the aa stickers and it was only advise not a request to use the oem stickers
    like i said i do not use the stickers at all and pre set my lights via the mot headlight tester as tourist mode for continental driving with xenon only lowers the beam pattern
    so i just do the same with my halogens and have yet to be flashed at
    i travel through very dark forest regions to my family home in Pontivy and need good illumination as the roads are very tight and twisty with little if any road markings and a few big drops if you get it wrong
    as you know the French will flash you if there blinded
  5. Re: A4 2011 SE - headlamp conversion for continental driving
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    £60 for stickers ! I bought VW acrylic headlamp protectors with stickers for my MK6 Golf for £40 . They fitted perfectly and can be re-used many times over. Seems that Audi parts prices are OTT !
    Skoda Octavia II SE 1.9PD TDI
  6. Re: A4 2011 SE - headlamp conversion for continental driving
    Feb 2010
    Liverpool
    I can adjust mine in the MMI menu to continental mode? Try this.
  7. Re: A4 2011 SE - headlamp conversion for continental driving
    Jul 2011
    Peterborough UK
    No - that only works if you have the Xenon and fancy MMI...which we don't!
  1. Continental Driving!
    By Mike'A in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 07-05-2010, 02:30 PM
  2. Question Headlamp conversion for driving abroad - what about LED running lights
    By markwilson in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 17-06-2009, 08:30 AM
  3. Question A4 dip headlamp conversion for EU driving
    By Chris714326 in forum Chat - Anything with wheels
    Last Post: 11-01-2009, 08:48 PM
  4. Headlamp conversion for driving in Europe
    By Sportingmac in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 13-08-2008, 08:52 PM
  5. S4 Headlamp Adjustment for Continental Driving
    By PBSmith in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-03-2007, 05:00 PM
