Thread: Fault Code Reading
Results 1 to 8 of 8
  1. Fault Code Reading
    chairman_mo Guest
    Anyone know of a garage in the West Midlands that could read the fault codes on my 94 V6 Coupe ?? The economy is dismal (20-25mpg) at the moment and I have a feeling all is not well under me bonnet . . . . . .
    Alternatively what software/leads do I need ??
    Cheers in advance, mo
  2. Re: Fault Code Reading
    Gwent
    A fault code read will not pick up a temp sender or lambda sensor problem unless it is completely failed, they can be faulty without showing up on a fault code scan. They are the usual culprits for poor mpg, prob best to get a multi meter out in your case?:
    http://www.12v.org/maintenance/repairs/ect.php
    http://www.12v.org/maintenance/repairs/o2sens.php
    http://www.12v.org/engine/index.php?...n=cl&view=rear
    If you decide to go for a VCDS lead, Rosstech have a 'free' version of their software for engine ECU fault code reads, VCDS lite. You usually need to purchase a licence to get the full functionality of the system. Leads come with a ODB2 interface (16 pin), you need to get an ODB1 (2 x 2) adaptor for use with the 80/coupe, something like these:
    http://cgi.ebay.co.uk/VAG-USB-DIAGNO...item4ced5b44c6
    http://cgi.ebay.co.uk/OBD-2-VAG-VW-A...item45f2a82c44
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: Fault Code Reading
    chairman_mo Guest
    Being an idle scrote and disinclined to get my multimeter out, roughly whats the damage for a temp sensor and a pair of lambda sensors??
  4. Re: Fault Code Reading
    Gwent
    There are possibly cheaper options, but lambdas here:http://www.lambdasensor.com/main/bos...tem=0258003396
    Temp sensor I guess approx £10-15 from ecp/gsf etc
    It isn't hard to carry out the tests, I would if I were you?
    Does the heater warm up in the usual time? thermostat stuck open would keep the engine cooler than it should be, temp sender then tells the ECU to keep the cold enrichment on
  5. Re: Fault Code Reading
    chairman_mo Guest
    Bleedin nora they aint cheap, time to break out the multi meter.
    Heater warms up ok and sits at 90C around town but cooler when on open roads, this seems to be normal to me.
    Cheers for the info
  6. Re: Fault Code Reading
    chairman_mo Guest
    Lamda sensors are kicking out voltage nicely between 0 and 0.9V
    Temp sensor still to do
  7. Re: Fault Code Reading
    Gwent
    Wallet breathes sigh of relief..
  8. Re: Fault Code Reading
    chairman_mo Guest
    Until I have to fill up
  1. Fault code reading
    By Tobster in forum 80 - 90
    Last Post: 29-11-2010, 11:00 AM
  2. dealershp no reading engine light code
    By 0000VW in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-08-2009, 04:34 PM
  3. Error code reading?
    By olliecampbell in forum Golf MK4 - 1999 - 2004
    Last Post: 12-08-2009, 10:02 PM
  4. Code reading with VAG com???
    By randall977 in forum VCDS - Help Requests
    Last Post: 02-07-2009, 12:06 PM
  5. VagCom - Fault code reading service - Chippenham
    By neilsgotaskoda in forum Octavia
    Last Post: 09-11-2008, 07:23 PM
