Thread: BUL Engine details
Results 1 to 10 of 12
  1. BUL Engine details
    warp_speed Guest
    I've got a 2.0TFSI BUL engine and noticed that there are two intercoolers on the car, I've got one in each of the openings next to the front fog lights, is that correct I was under the impression that there is only one, is this because the engine is the 217 hp one?
  2. Re: BUL Engine details
    May 2009
    Berkshire
    No, all 2.0TFSi A4's have two side mounted intercoolers.
    Audi A4 2.0 TFSi DTM Quattro
    290BHP/275lbft
    "I can resist anything but temptation"
  3. Re: BUL Engine details
    warp_speed Guest
    Does anyone have any engine diagrams for this engine, I'm a geek when it comes to mechanical stuff and seeing how everything plugs together would be fantastic :-)
  4. Re: BUL Engine details
    Mar 2011
    Kendal Cumbria UK
    Dont all turbocharged A4's have two? in fact i cant recall seeing a turbo VAG without two?!
    Dan
    2002 A4 B6 2.5 TDI Quattro Sport - Mods to date... Too Many To List!
  5. Re: BUL Engine details
    Norwich
    Not sure about the lower powered diesels- my 1.9TDI B7 had a blanking plate over the air intake on one side.
  6. Re: BUL Engine details
    warp_speed Guest
    I'm wondering how a dual intercooler system would work, as far as I know you need to cool the air coming into the cylinders because pressurised air increases in temperature. Think I'll check wikipedia
  7. Re: BUL Engine details
    Mar 2011
    Kendal Cumbria UK
    the charge passes into one IC, out of it into a pipe that runs under the Rad/AC Rad and into the second IC then into the inlet. IIRC it goes to the drivers side first then the passenger side. Or at least it does on my 2.5 Tdi A4.
    Dan
  8. Re: BUL Engine details
    Nov 2008
    Exactly as dan. stated.
    Due to lack of space in front of the engine, two side intercoolers where fitted instead of a larger central one.
    It works very well for standard and mildly tweaked engines.
    My intake temps according to vagcom are not much more than ambient. Last time I ran a data log check ambient was 18c. Max. intake temp. was 38c. The max occurred after coming to a halt after a run.
    The TT Mk1 (225ps &245ps) also used a series linked twin intercooler setup.
    2006 A4 saloon 2.0T S-Line Special Edition.
    Mauritius Blue - Xenons, Bose, Heated Valcona, Cruise, Colour DIS, Ipod, Revo. Big Smile.
  9. Re: BUL Engine details
    warp_speed Guest
    Brilliant thanks for the info. Just a general Turbo question, without the intercooler how hot would the air get when compressed, I mean it must get hot if it starts to explode before reaching the cylinders?
  10. Re: BUL Engine details
    Mar 2011
    Kendal Cumbria UK
    It doesnt explode before it reaches the cylinders mate, it would get hot though, and therefore less dense, hence the IC which cools the air, which increases the density but i think decreases the pressure, mind you its still at a higher pressure than a NA car. I honestly dont know how hot it would get but itll be high as its been compressed right next to the turbine housing for the exhaust side of the turbo which gets red hot, as in glowing on some cars, my mates scoob once melted the little plate with the turbo details on it it got that hot.
    Dan
  1. Fireware details!
    By Sludger in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-10-2010, 05:40 PM
  2. lifter tick bul engine?
    By stevo-dtm in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-08-2010, 09:23 AM
  3. common problems BUL engine
    Last Post: 13-06-2010, 06:21 PM
  4. Contact details for VW?
    By andy8442 in forum Chat - Completely Off Topic
    Last Post: 05-10-2009, 09:40 AM
  5. personal details
    By a8 tech in forum Chat - Completely Off Topic
    Last Post: 03-12-2007, 11:05 AM
