Thread: Help! VCDS biff..
  1. Help! VCDS biff..
    Jun 2011
    Manchester England
    Can anyone help with this problem. I connected my Ross-Tech VCDS in order to check for fault codes. It seems that after disconnecting, i have rough idling along with a rattling noise??!! Can the fuel mapping, or Injection timing be altered purely by connection?
    The noise stops if the engine revs are increased, but is there on start-up and idle.
    There was no noise before I conneted, and no faults were logged! None of the settings were changed or even viewed. Now I'm confused!
    Can anyone with a clue shed some light on it? Thanks in advance.
    Degsy
  2. Re: Help! VCDS biff..
    Norfolk
    It helps if you post an autoscan and give details of make/model/engine/yesr etc. No VCDS cannot cause changes to occur...You have to make them.
  3. Re: Help! VCDS biff..
    2007 Post(s)
    Sometimes clearing codes can make an engine in limp mode run rough, did you clear any codes?
  4. Re: Help! VCDS biff..
    Jun 2011
    Manchester England
    Hi guys, cheers for your replies.
    Audi A4 Avant 1.9tdi 2004 Multitronic
    I cleared the following codes. I didnt know that the trans faults could have an impact on the running of the engine. There were no engine faults logged, only the 2 transmission ones below.
    It is occasionally in limp mode, but for the G/Box ECU fault. I have the occasional flashing PRNDS block. I plan to remove the ECU? (Magic Box) and send it away for repair. Any advice on that too would also be great.
    Thanks again.
    Degsy
    Address 02: Auto Trans Labels: 01J-927-156.lbl
    Control Module Part Number: 8E0 910 155 C HW: 01J 927 156 HH
    Component and/or Version: V30 01J 1.9l PD RdW 3220
    Software Coding: 0000001
    Work Shop Code: WSC 63251 000 00000
    VCID: 25446D939571
    2 Faults Found:
    17090 - Transmission Range Sensor (F125): Implausible Signal
    P0706 - 000 - -
    Freeze Frame:
    RPM: 96 /min
    RPM: 0 /min
    RPM: 0 /min
    (no units): 1.0
    Torque: -32.0 Nm
    Temperature: 45.0°C
    T.B. Angle: 0.0°
    Bin. Bits: 0001 0 0
    18201 - Transmission Output Speed Sensor 2 (G196): No Signal
    P1793 - 000 - - - Intermittent
    Freeze Frame:
  5. Re: Help! VCDS biff..
    2007 Post(s)
    You need a new gearbox ECU.
  1. advice on buying VCDS/VCDS-lite
    By borakev in forum VCDS - General Questions
    Last Post: 16-04-2019, 05:20 PM
  2. help please in need of vcds
    By ants a4 in forum VCDS - Users Locations
    Last Post: 25-02-2011, 07:22 PM
  3. vcds
    By bikesken450 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-02-2011, 10:39 PM
  4. vcds help
    By dilun in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-10-2010, 01:14 PM
  5. vcds help
    By autodoc in forum VCDS - Users Locations
    Last Post: 06-10-2009, 02:18 AM
