This relates to another post regarding my Malfunctioning ESP. After some repair work which i though would sort out the ESP, i now have 2 fault codes relating to the Steering Wheel Electronics. Can anyone advised me on how to fix this? (or anything else they can see)
Friday,10,June,2011,11:13:50:37015
VCDS Version: Release 10.6.4
Data version: 20110418
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ7W610580 Mileage: 129760km/80629miles
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 KS HW: 03G 906 021 KS
Component: R4 2,0L EDC 000SG 9187
Revision: --H06--- Serial number: VWZ7Z0G8093406
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 7AF01A984C4F
2 Faults Found:
005784 - Please Check DTC Memory of Steering Wheel Electronics
P1698 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 129760 km
Time Indication: 0
Date: 2000.00.00
Time: 10:55:31
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 11001100
Bin. Bits: 00000000
(no units): 0.0
005785 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
P1699 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 129760 km
Time Indication: 0
Date: 2000.00.00
Time: 11:00:24
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 11000100
Bin. Bits: 00000000
(no units): 0.0
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023282
Shop #: WSC 01392 785 00200
VCID: 73EE37BC6B25
No fault code found.
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 FT HW: 1K0 820 047 FT
Component: Climatic PQ35 141 0909
Revision: 00141027 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 7BFE1F9C4375
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000006868782
Coding: E5890F2700041800470A00000F00000000085D035C0001
Shop #: WSC 01367 785 00200
VCID: 6CDC2CC0361B
Part No: 5M0 955 119 B
Component: Wischer 080307 020 0501
Coding: 00038805
Shop #: WSC 01367
Part No: 1K0 955 559 AD
Component: RLS 050307 014 1201
Coding: 06500389
Shop #: WSC 01367
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 1K AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1496H0
Coding: 0012619
Shop #: WSC 01373 785 00200
VCID: 3D7AD1841DE1
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BD HW: 1K0 953 549 BD
Component: J0527 638 0070
Coding: 0002002
VCID: 75EA09A46551
Part No: XXXXXXXXXXX
Component: E0221 002 0010
1 Fault Found:
00895 - Cruise Control Switch (E45)
014 - Defective - Intermittent
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 973 B HW: 1K0 920 973 B
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWZ7Z0G8093406
Coding: 0003403
Shop #: WSC 00875 210 92206
VCID: 2C5CECC0F69B
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 180307F1002305
Coding: 3D3F034007009003
VCID: 2F66FBCCC78D
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1610
VCID: 2C5CECC0F69B
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 005 0990
Coding: 0000692
VCID: 3874C09032C3
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
Shop #: WSC 00000 028 00001
VCID: 356AC9A425D1
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 819002005103087F2D04840570085FC690FC00
VCID: 830EE77CBB85
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Component: Innenraumueberw.003 0203
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000692
VCID: 3972C59409C9
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 5M0 035 186 C
Component: Radio GR0 034 0033
Revision: 0003404S Serial number: VWZ2Z2G3323752
Coding: 0010400
VCID: 2C5CECC0F69B
1 Fault Found:
01042 - Control Module; Not Coded
000 - -
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 005 0914
Coding: 0000144
Shop #: WSC 01392 785 1012552
VCID: 3874C09032C3
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
VCID: 3972C59409C9
