Thread: ESP Fault and No Dash Symbol
Results 1 to 9 of 9
  1. ESP Fault and No Dash Symbol
    kevshek Guest
    I was wondering if anyone could clarify, when you turn the ignition ON, aswell as the ABS, Handbrake light etc, does the ESP (skiddy car and tyre track) Symbol come on momentarily prior to cranking the engine?
    My does not light up at all, and the ESP OFF switch on the centre console doesnt do anything. Im also sure my car will wheelspin in the wet.
    Ive just had it back from a warranty repair. After scanning the ECU, there was a fault with the ABS Pressure Sensor, this i was told could stop the operation of the ESP. However, even after its now been fixed and the fault code has been cleared, ESP is still not functioning.
    Heres a scan i took today, although its a Plus, i presume its the same as a normal mk5.
    Could the 2 Steering Wheel Electronc faults be responsible?
    Friday,10,June,2011,11:13:50:37015
    VCDS Version: Release 10.6.4
    Data version: 20110418
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZ7W610580 Mileage: 129760km/80629miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 021 KS HW: 03G 906 021 KS
    Component: R4 2,0L EDC 000SG 9187
    Revision: --H06--- Serial number: VWZ7Z0G8093406
    Coding: 0000072
    Shop #: WSC 66565 257 00032
    VCID: 7AF01A984C4F
    2 Faults Found:
    005784 - Please Check DTC Memory of Steering Wheel Electronics
    P1698 - 001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 129760 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 10:55:31
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.46 V
    Bin. Bits: 11001100
    Bin. Bits: 00000000
    (no units): 0.0
    005785 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
    P1699 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 129760 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 11:00:24
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.39 V
    Bin. Bits: 11000100
    Bin. Bits: 00000000
    (no units): 0.0
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0023282
    Shop #: WSC 01392 785 00200
    VCID: 73EE37BC6B25
    No fault code found.
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No SW: 1K0 820 047 FT HW: 1K0 820 047 FT
    Component: Climatic PQ35 141 0909
    Revision: 00141027 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 7BFE1F9C4375
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
    Component: Bordnetz-SG H52 2002
    Revision: 00H52000 Serial number: 00000006868782
    Coding: E5890F2700041800470A00000F00000000085D035C0001
    Shop #: WSC 01367 785 00200
    VCID: 6CDC2CC0361B
    Part No: 5M0 955 119 B
    Component: Wischer 080307 020 0501
    Coding: 00038805
    Shop #: WSC 01367
    Part No: 1K0 955 559 AD
    Component: RLS 050307 014 1201
    Coding: 06500389
    Shop #: WSC 01367
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: 1K AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PD1496H0
    Coding: 0012619
    Shop #: WSC 01373 785 00200
    VCID: 3D7AD1841DE1
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 BD HW: 1K0 953 549 BD
    Component: J0527 638 0070
    Coding: 0002002
    VCID: 75EA09A46551
    Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    1 Fault Found:
    00895 - Cruise Control Switch (E45)
    014 - Defective - Intermittent
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1K0 920 973 B HW: 1K0 920 973 B
    Component: KOMBIINSTRUMENT VDD 1610
    Revision: V0003000 Serial number: VWZ7Z0G8093406
    Coding: 0003403
    Shop #: WSC 00875 210 92206
    VCID: 2C5CECC0F69B
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 K HW: 1K0 907 951
    Component: J533__Gateway H04 0021
    Revision: H04 02 Serial number: 180307F1002305
    Coding: 3D3F034007009003
    VCID: 2F66FBCCC78D
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VDD 1610
    VCID: 2C5CECC0F69B
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
    Component: Tuer-SG 005 0990
    Coding: 0000692
    VCID: 3874C09032C3
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 L
    Component: EPS_ZFLS Kl.070 H07 1806
    Shop #: WSC 00000 028 00001
    VCID: 356AC9A425D1
    Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
    Component: KSG PQ35 G2 020 0203
    Revision: 00020000 Serial number: 00000000000000
    Coding: 819002005103087F2D04840570085FC690FC00
    VCID: 830EE77CBB85
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 951 178 A
    Component: Neigungssensor 003 0203
    Component: Innenraumueberw.003 0203
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
    Coding: 0000692
    VCID: 3972C59409C9
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No: 5M0 035 186 C
    Component: Radio GR0 034 0033
    Revision: 0003404S Serial number: VWZ2Z2G3323752
    Coding: 0010400
    VCID: 2C5CECC0F69B
    1 Fault Found:
    01042 - Control Module; Not Coded
    000 - -
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
    Component: Tuer-SG 005 0914
    Coding: 0000144
    Shop #: WSC 01392 785 1012552
    VCID: 3874C09032C3
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
    Coding: 0000144
    VCID: 3972C59409C9
  2. Re: ESP Fault and No Dash Symbol
    Up North
    Can't help with the scan info but try this - with engine running, turn off the ESP. Light should come on. Turn it on again, light should go off. This ought to be a pretty good indicator of things.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  3. Re: ESP Fault and No Dash Symbol
    kevshek Guest
    I know thats how its supposed to work, but mine doesnt, neither the button or the dash light lights up at all. The only thing i think it can relate too is the DTC memory steering electronic fault mentioned above. ESP uses wheel speed signal, steering angle etc to calculate intervention, maybe this fault has shut it down.
    Someone mentioned that there maybe a proceedure to reset the DTC of the steering wheel, and it was probably caused when i had the wheel off installing cruise control. If anyone can shed any light on the steering wheel thing, that may help.
  4. Re: ESP Fault and No Dash Symbol
    Oct 2009
    Wiltshire England
    From what you have described regarding the ESP light not coming on atall it looks like someone has removed the bulb to mask the ESP malfunction issue (ABS pump problem, common fault).
    I would surgest that you return the car back to where or who ever did the warranty work and ask them to explain what they have done to rectify the ESP not working issue. Then point out to them that it is still not working and it appears that the ESP dash light has been removed seeing that it does not seem to work.
    The ESP not working is a common problem (we have it on my wifes tdi Touran) it is something we are going to live without seeing to rectify this issue is megga bucks.
    Good luck.
  5. Re: ESP Fault and No Dash Symbol
    kevshek Guest
    I also had the same though, and was told that the ESP light was an LED when i asked. These are usually harder to mask as you wouldneed to dismantle the gauge cluster to blank it, but its would explain a lot. There looks like some dust behind the perspex and it could be possible someones been in there, so i might investigate myself. I dont think the used car dealer where i gotit from would come clean. The way they deal with sale and service/repairsare totally seperate (not even on the same site!) This means if you have a problem, its no use going back to the showroom, which is very sneaker clever. However, the warranty was good enough to cover the repairs. If need be, i can lways make further claims to rectify it.
  6. Re: ESP Fault and No Dash Symbol
    Oct 2009
    Wiltshire England
    When I investigated the ESP light issue for my wifes Touran I found a thread here that described your exact same issue. That person found that a plug(I'm not quite sure where) had been disconnected thus removing the warning light on the dash.
    Have a look through the VW Touran dart of the forum and you will probably find this thread and several other cases.
    All I know to rectify this ESP issue you will need to part with upto and beyond £1200
    Buzz
  7. Re: ESP Fault and No Dash Symbol
    Jul 2008
    VW have issued a repair kit for the ESP fault, our Mk5 Golf with over 100K VW service history, although one a specialist and we have been offered 75% good will gesture.
    Dealer tried to offload full new unit for over £1k but repair kit is £400 and a bit!
    Worth checkng out
  8. Re: ESP Fault and No Dash Symbol
    Oct 2009
    Wiltshire England
    I was informed by my local VW dealer that there was a "bolt on" repair kit however they also said that this kit would only work on some of the abs pumps. It turns out that there are different abs pumps and not all can be fixed with this kit. When I questioned Vw asking them if our Touran could have the bolt on kit fitted they replied that they could not tell via our number plate or vin number and that they would need the vehicle in for investigation(at our expenxce). To be honest I understand that even if we had a brand new replacment item fitted this item will fail in time too.
    We are happy enough with not having the esp working (years ago we had a 110bhp passat 1.9tdi that never had esp and it drove fine) after all the Touran is no rocket ship and we have had no issues with it not working.
    ESP is nice to have but not cost effective if you have to pay the repair bill for it.
  9. Re: ESP Fault and No Dash Symbol
    does this ESP issue effects 2008 models as well? Kinder bit worried now???
  1. ESP Warning Symbol
    By kid-jensen in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-05-2010, 10:04 PM
  2. Strange symbol in the dash
    By wmccann in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-02-2010, 10:51 AM
  3. Red Symbol on dash - Coolant
    By hayley in forum TT - 8N Forum - 1998 - 2006
    Last Post: 02-12-2009, 05:03 PM
  4. warning symbol on dash?
    By Yosemite Sam in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-04-2008, 07:37 PM
  5. Dash symbol and heater problem !
    By tigerminx1 in forum Audi A3 - Archive Topics
    Last Post: 01-05-2007, 01:07 PM
